ATTN.: ALL BBK OWNERS
Old Aug 11, 2009 | 05:37 PM
bahawton's Avatar
bahawton
My local Mini dealer won't look for the cause for an annoying metallic clicking noise that happens when turning while NOT using the brakes 'till I remove my Wilwood brakes...
See thread below for details:
https://www.northamericanmotoring.co...e-turning.html
I just received all the stock parts less rotors from Dr Obnxs (WHAT A GUY!!!).
Would anyone be willing to have me pay shipping for their old stock rotors so I can return them 2- 4 weeks later?
Old Aug 11, 2009 | 07:06 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Have you tried other means to discover the cause ? Seems like a lot of trouble to find the noise....
Things I would try first before removing BBK.
1) Check your brake sensor wire to see if it came loose and is dangling like a baseball card in the spokes of a bike tire....
2) Remove wheel tire where noise is coming from, examine brakes and assembly for malfunction, if nothing...
3) Rotate tires. ( does the noise follow the tire moved ?)
4) Have someone put vehicle up on rack - A Meineke Muffler Shop ? and look for something under the car near area of noise
5) FIND ANOTHER MINI DEALER......short answer, the one you went to suks.
Old Aug 11, 2009 | 09:00 PM
matma92ser's Avatar
matma92ser
My Wilwood BBK makes a weird metallic scraping on-off sound on one side only, and only while turning away from that side. I took the brake pads out and chamfered the leading edge. The noise went away.
Old Aug 11, 2009 | 09:33 PM
searocko's Avatar
searocko
Oh man, I just dumped a pair of heat-checked cryo rotors into the recycle bin yesterday. And to top it off, I'm local to you! Have you posted on psmini.org to see if anyone has a set lying around?
I saw your post on the other thread and I can't believe the shop foreman at Northwest MINI told you two piece rotors are illegal!
Old Aug 12, 2009 | 08:59 AM
bahawton's Avatar
bahawton
gray raven- I don't have sensors on my Wilwoods & I tried the rest of your solutions with no luck. There are no other dealers in my area, so this is my final option.
searocko- I guess I should of posted this last week instead of being lazy...
Old Aug 12, 2009 | 10:19 AM
Dinan604's Avatar
Dinan604
Do this. You should chamfer pads on most slotted rotors on the leading edge.
Old Aug 12, 2009 | 10:24 AM
Motor On's Avatar
Motor On
Sounds like an "overtightened hub" to me if you can locate it to a specific wheel.
Also I'd be looking for a good BMW or European car specialist shop, or be making a bit of a drive to save from having to replace an entire brake system.
Old Aug 17, 2009 | 08:20 PM
bahawton's Avatar
bahawton
Dinan604- It's a metallic clicking sound, but I may give the chamfering idea a try...
Motor On- The dealer checked the axle nuts last time I was there so that's not the problem. Also, finding another European car speacialist would cost me a lot of money- This should be a warranty issue. The only thing left is the transmission/LSD if the stock brakes don't make the noise go away & I aint paying for that fix on a car with 12K miles on it.
Back to my original request...
Anyone have some old stock rotors to borrow???
tacticalbacon02
NEO Miniacs (Mini NEO)
Oct 4, 2019 07:18 PM
jacobj
Tires, Wheels, & Brakes
Oct 4, 2015 11:49 AM
USA-RET
Sep 8, 2015 01:50 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
