R56 Does this connect to something?
Old Aug 8, 2009 | 05:41 PM
Benibiker's Avatar
Benibiker
I was messing around under my bonnet today and I noticed what looks like a loose tube that should be connected to something. The car runs fine but if you look at the picture, it's the shiny black tube in the center that curves up. It's on the right side of the engine, to the right is the fuse box and to the left is the air-cleaner intake tube. It's not connected to anything, can it be a vent of some sort? I can't trace the other end, it just disappears down towards the transmission. Can you guys with an automatic transmission check and see if you have this same tube just sitting there? Thanks!
Old Aug 8, 2009 | 07:01 PM
mellowmcs's Avatar
mellowmcs
it's only suppose to be connected at one end (to the transmission) that's the vent pipe
nothing to worry about #6 in the image above
Old Aug 8, 2009 | 07:15 PM
Benibiker's Avatar
Benibiker
Cool, thanks for checking mellomcs! I never noticed it before and it just looked out of place this time around...
buggyeye401
Oct 1, 2015 01:22 PM
point665
Sep 29, 2015 12:41 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
buggyeye401
Sep 28, 2015 04:09 PM
