R52 Window Tinting?
Old Aug 6, 2009 | 09:25 AM
Perfusion's Avatar
Perfusion
Window Tinting?
A question for those of you whom have tinted the windows on your cabrio: How?!
Whenever I've had (side) windows tinted on cars in the past, the tinter has always said, "Okay, now just *don't* roll down the windows for _______ (amount of time)."
That was easy enough to accomplish, but on the Mini cabrios, the windows automatically roll down a centimeter or so every time the door is opened. Wouldn't that cause problems during the tinting process, as well, i.e. the tint will be applied with the door open, so the film won't go all the way to the bottom? If the tint is applied from the inside with the door shut, won't it wrinkle at the bottom the first time the door is opened (i.e., when the installer wishes to get out of the car)?
Maybe I'm overthinking this, and maybe tint films have come along way. I don't know. I just know that I would like a light tint on my front windows, but I don't want to put the car through major surgery to have it done...
Any and all suggestions are welcomed!
Old Aug 6, 2009 | 11:08 AM
drsilvermini's Avatar
drsilvermini
The windows go down a little bit in the hardtops too. I just had my windows tinted and the guy who did it said not to put the windows down for 3 days. I got in and out of the car many times and it did not mess up the tint.
Old Aug 6, 2009 | 03:40 PM
smieska's Avatar
smieska
If the tinter is any good the window up/down should not be a problem. I had mine done a few months ago and like already stated they suggested not to roll them down for 3 days. They have a way to work around the door opening window down thing.
Old Aug 6, 2009 | 03:52 PM
MINIchaser's Avatar
MINIchaser
Yes, it happens like that on the hardtops too. I had mine done in December and whether he was blowin smoke or not he said they have a way to turn off that feature just temporarily while they're applying it. He said it shouldn't be a problem with normal use and that they put some extra "stickiness" or something on the edges. It wasn't stickiness I just can't remember the term he used. The place I got mine done does high end vehicles, and they know what they're doing. I didn't have a problem with mine, and I went darkest possible.
so...in essence: go for it!
Old Aug 6, 2009 | 07:56 PM
Perfusion's Avatar
Perfusion
The only way I could think of getting around it is to disconnect the battery, which I do hope they won't do. I hate losing all my presets, etc. Nonetheless, I'll call around to some well-recommended tinters in the area and see what's what. Thanks for the replies, all.
Old Sep 3, 2009 | 11:53 AM
TigerDave's Avatar
TigerDave
I do my own window tinting. I've done roughly 5 or so cars in the past few years. When I did our 2003 Cooper hatchback, I didn't know that the window dropped a fraction of an inch when the doors were opened. So imagine my surprise when all was said and done only to find out that as soon as I closed the door, the window went up and exposed a thin strip of untinted glass! I had to rip them out and do them over again.
Lesson learned.
My work-around was to simply cut the film so that it was about a centimeter taller than the glass. Once I peeled back the liner and applied the top half of the film to the glass, I got in the car and closed the door. The window went up and I was able to apply the bottom half the few mm of excess in behind the rubber trim.
We since sold the '03 and last weekend bought an '06 S convertible. I'll be tinting this one too (which will be easier with the top down and out of the way). Plus the back window is nice and flat. The curvature of the hatchback drove me crazy. Took me about 10 tries to get that one tinted.
Anyway, to address some of the questions above, the adhesive on quality film is pretty strong, so the auto-dropping/raising of the windows won't screw up a freshly-installed job. I still recommend NOT opening the side windows fully for 3-7 days (shorter in warmer weather). I also recommend parking the car out in the hot sun with the sunroof cracked open so the water can dry ASAP. Hope this helps!
Old Sep 3, 2009 | 02:22 PM
Rossii's Avatar
Rossii
Just had mine tinted and asked the same question. What he did was to use a heat gun around the edges of the windows this helped it to cure enough so the tint wouldnt move when the windows went down. Didnt have any issues.
Old Sep 3, 2009 | 02:27 PM
TigerDave's Avatar
TigerDave
Exactly. I used my heat gun to help the film conform (shrink-to-fit) the curvature of the window as well as speed up the drying process as the slip solution is sandwiched between the film and the glass.
Slippage should be a non-issue. The film should glide smoothly against the window edge felt.
Old Sep 3, 2009 | 02:56 PM
MINIchaser's Avatar
MINIchaser
hmm, yea I have no idea if they disconnected the battery...
the guy probably just told me a bunch of baloney
Old Sep 20, 2009 | 12:44 PM
Rodjockey's Avatar
Rodjockey
Mine was a multi step process first they did the rear window, then I put the top down and rolled up my windows. They did the front and rear windows and then put the top back up and it's still fine.
Old Sep 20, 2009 | 02:21 PM
ngweibing's Avatar
ngweibing
how long did it take?
Old Sep 20, 2009 | 05:59 PM
Rodjockey's Avatar
Rodjockey
About four hours for the install, I had to lower my back seats so he could get to the rear window...it's really tight he cursed the entire time but he got it.
Old Oct 3, 2009 | 11:01 AM
waltermb's Avatar
waltermb
anyone find a top notch tint company in atlanta? mine need to be redone. thanks!
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
krohm
Sep 28, 2015 12:16 PM
whowantstorace
Sep 27, 2015 06:16 PM
