R50/53 Recharging a/c refrigerant on 05 S?
Old Aug 1, 2009 | 04:35 PM
john411's Avatar
john411
It's blowing ambient air. The problem is I can't locate where to refill plus the a/c refill that I have brings "stop leak technology."
The car is still under warranty but if I can do it in 15 minutes it's better than taking the car to the dealer and having them spend the whole day fixing it.
Old Aug 2, 2009 | 10:51 AM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by john411
...The car is still under warranty but if I can do it in 15 minutes it's better than taking the car to the dealer and having them spend the whole day fixing it.
If it is under warranty then it is best left to the Mini techs. AC is closed system and if it is low then there is a leak. The way to find the leak is to totally evacuate the system and if the leak is not apparent under vacuum then pressurize with nitrogen. If you fill it yourself you won't really know how much to put in and you wouldn't have fixed the problem. It's much better to have then do it if it will be on their dime.
Rich
Old Aug 2, 2009 | 12:07 PM
john411's Avatar
john411
Thanks for the reply. Can't believe it took so long for someone to reply. This forum must be dead.
Where can I locate the a/c under the hood? I have a gauge to check the pressure but I can't see the condenser. Where is it?
THanks
Old Aug 2, 2009 | 12:58 PM
Yo'sDad's Avatar
Yo'sDad
If you can't find the condenser, and can't find the A/C connections, I'm not trying to be a schmart **** here, but I suggest you not try to do this yourself.
You certainly do not want to try to save some time doing it yourself and messing it up and potentially getting your warrantied voided... just bite the bullet, take some paper work or your laptop along and get some work done while they are fixing your leak properly. You'll be glad you did.
YD
Old Aug 2, 2009 | 01:15 PM
papa-j's Avatar
papa-j
I annotated an image and attached it. Hope it helps.
Also:
Find your model
http://www.realoem.com/bmw/showparts.do?
Coolant lines (under hood, LH side, near headlight)
http://www.realoem.com/bmw/showparts...19&hg=64&fg=60
Condensor (way out front)
http://www.realoem.com/bmw/showparts...17&hg=64&fg=55
Attached Thumbnails Recharging a/c refrigerant on 05 S?-mini-ac-help.jpg
Old Aug 2, 2009 | 03:09 PM
john411's Avatar
john411
Thanks a lot. I'll try to see if there is pressure and then probably make an appointment with the dealer.
Old Aug 2, 2009 | 06:05 PM
Rich.Wolfson
If you are using one of those gauges from Interdynamics then I suggest you simply throw it away before you damage something. Their products are garbage. And how much Freon would you put in? There are concerns of overcharging that would be expensive to fix if you did put too much in on the suction side.
And if somehow you hooked your gauge to the high side, then all sorts of bad things can happen.
That said I find that the Mini comes with a short charge and many times it only needs a bit of Freon to bring the system to a place where it works on hot days. But you said yours is blowing ambient temps. In that case, trust me, you are best leaving it to someone with the right tools and experience.
Rich
Old Aug 2, 2009 | 06:08 PM
john411's Avatar
john411
Yeah, I'm taking it to the dealer tomorrow or whatever day they tell me to come in.
rikaro
Nov 24, 2015 02:05 PM
Brochacho
Sep 29, 2015 10:24 AM
Nicefeet
Sep 27, 2015 11:14 AM
dragonby
Sep 25, 2015 08:10 PM
bneer
Sep 20, 2015 11:29 AM
