R50/53 One Ball - Pop\Crack on Throttle Release
Old Jul 30, 2009 | 08:11 AM
GB1's Avatar
GB1
I have an '04 S, and am looking to release some of the back pressure of the stock system without spending alot of $$$ and keeping the original tips.
Hence I have been contemplating the 1 ball system, but it a little loud for where I live and I do not like the popping\crackling on throttle release.
I have a Alta CAI, and 2% reduction pully and use the vehicle for city driving and HPDE.
Could a small resonator before the one ball reduce this?
Any advice is greatly appreciated.
Pat
Old Jul 30, 2009 | 08:25 AM
Bigshot's Avatar
Bigshot
Have you done the one-ball, from your post it seems like you are considering it.
It shouldn't be much louder than stock, just a bit deeper. No complaints on mine.
Old Jul 30, 2009 | 09:24 AM
Crashton's Avatar
Crashton
Pat-If you do a one ball & for some reason you feel it is too loud just add a small resonator in the straight pipe aft of the cat. The shop that does your one ball should have no problems adding a resonator if it is needed.
Old Jul 30, 2009 | 09:57 AM
GB1's Avatar
GB1
Thanks guys
Old Jul 30, 2009 | 10:32 AM
k-huevo's Avatar
k-huevo
The one-ball sounds much better with a straight through muffler/resonator after the header flange. As you suspected it eliminates the popping noise. If you replace the OE flange with an aftermarket piece, the narrow neck-down after the flange will be removed from the flow path, another plus.
I recommend going one step further and deleting the header’s pre-cat.
Old Jul 30, 2009 | 10:52 AM
GB1's Avatar
GB1
So I should eliminate the precat, add a resonator after the cat, and then do the one ball
Thanks,
Pat
Old Jul 30, 2009 | 11:37 AM
Crashton's Avatar
Crashton
If you have any state inspections where you live your car will most likely fail with the pre-cat removed.
Old Jul 31, 2009 | 10:50 AM
ZCCROW23's Avatar
ZCCROW23
OHIO! What's up? I'm from Canal Fulton by Massillon area originally, but now I'm in the service stationed in Tucson. Always nice to talk to a fellow Buckeye! Anyways, I'm looking at getting the one ball done to my 06 MCS and was wondering if any normal shop will do this like Midas or my local mechanic who changes my oil. Also, I recently purchased a 03 MC for my wife and was wanting to do small mods to make the little guy sound like it's big brother. LOL. Can I do the same for the 03 MC or is there no resonator to cut out and bypass? Thanks.
Old Aug 3, 2009 | 10:52 AM
GB1's Avatar
GB1
I just did it this weekend, and am happy with the results.
Thanks,
Pat
Old Aug 3, 2009 | 11:16 AM
Crashton's Avatar
Crashton
Pat-Glad to hear it worked out for you. What is the going rate for a one ball conversion where you live?
BernieCoop
Sep 10, 2021 03:15 AM
embiggenedmini
Oct 15, 2015 12:36 PM
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
Sep 3, 2015 02:06 PM
