Suspension camber correction question
Old Jul 26, 2009 | 12:20 AM
catnjosh15's Avatar
catnjosh15
how much will the camber change when one lowers a mini about an inch? can the camber be corrected back to stock or really close? oh, this is for all four wheels. i am about to buy the H&R touring cup kit and need to know if i need to buy other parts to help correct the geometry; don't want uneven tire wear.
thanks
Old Jul 26, 2009 | 12:18 PM
AutoXCooper.com's Avatar
AutoXCooper.com
There is no camber adjustment in the front on a MINI, only Toe.
If the MINI was built in or after Jan 2005 there is a little rear camber adjustment. Check the drivers door jam for the build date.
Key after install is getting the Toe settings back to OEM Spec. Bad toe will eat tires fast.
Old Jul 28, 2009 | 04:45 AM
snid's Avatar
snid
You will probably want / need adjustable rear control arms to adjust the camber in the rear.
Old Jul 28, 2009 | 05:17 AM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
At the minimum you'll have to get a set of Rear Control Arms. Otherwise you'll just eat through the rear tires. For the front you should be ok, but when you lower the car you will add neg camber which is good. But it may not be perfectly even left to right. So adding a set of adjustable camber plates up front would make it so you could even it out. Not totally necessary but they would be simple to install while doing your coilovers.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Hippiehobbit267
Dec 3, 2019 04:22 PM
WestfaliaR
Aug 19, 2015 08:01 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
