R57 Diagonal cross braces don't fit after exhaust install.
Old Jul 22, 2009 | 09:44 AM
SprintA3's Avatar
SprintA3
After installing the Alta exhaust for a Cooper S Hatchback, the diagonal cross braces under the car no longer fit. They do not clear the exhaust.
1) Are these cross braces used for anything other than stiffening the chassis?
2) Are there any solutions to this problem or has anyone else run into it?
Thanks.
Old Jul 22, 2009 | 10:50 AM
AutoXCooper.com's Avatar
AutoXCooper.com
on the 1st gen cabrios the guys put spacers between the brace and body to give it the space needed.
see https://www.northamericanmotoring.co...737-post3.html
Old Jul 22, 2009 | 11:57 AM
SprintA3's Avatar
SprintA3
That does look like a valid solution.
I think we might need some more room than that though. Would using this type of spacer compromise the handling characteristic of the car?
Old Jul 22, 2009 | 12:03 PM
AutoXCooper.com
on the 1st gen cabs it was not a handling brace it's a safety brace to help stop that SUV from hitting the back of your front seats in a rear ender.
Old Jul 22, 2009 | 12:10 PM
SprintA3's Avatar
SprintA3
They look like they are for stiffening the chassis on the R56. Here are some pictures of the problem.
Old Jul 22, 2009 | 12:19 PM
AutoXCooper.com
where all is it hitting?
Old Jul 22, 2009 | 12:27 PM
SprintA3's Avatar
SprintA3
I believe its hitting the forward most resonator right after the cat. Those are just the photos from the shop that is doing to install.
I'm not installing it, I'm just trying to fix the problem.
Old Jul 22, 2009 | 12:30 PM
AutoXCooper.com
I'd call Alta tech and see what they say. If that Catback was not changed to fit the R57 you will need to make some kind a spacer system.
Old Jul 22, 2009 | 04:34 PM
SprintA3's Avatar
SprintA3
Thanks for all of your help. The problem is solved momentarily with a spacer. That will be replaced with a new brace that is made specifically to fit this exhaust. I'll post pics of it when I get home.
Old Jul 22, 2009 | 08:53 PM
phillyMCS's Avatar
phillyMCS
Please let me know how this project goes because I'd like to install an exhaust as well, and it seems like there aren't any exhaust designed for the R57.
Old Jul 23, 2009 | 06:55 AM
SprintA3's Avatar
SprintA3
I'll post pics later today. I've been busy with work so I couldn't get the pics of what we went with last night.
Its essentially a spacer like the pictures that Dustin posted, but it is slightly larger for the R57. This is only temporary though. We will be figuring out a permanent solution in the near future. More likely than not it will be a custom rear brace.
Thanks again to Dustin for all of his help yesterday.
Old Jul 23, 2009 | 06:58 AM
SprintA3's Avatar
SprintA3
And just for the record, the Alta system sounds fantastic. Slightly more mellow than my dad's JCW R56, but much better sounding than stock. When the car pulls away it sounds great.
Old Jul 23, 2009 | 07:50 AM
mtubesing's Avatar
mtubesing
Let us know when that permanent fix is available. Catback replacement is definitely on my short list for my R57. I've been sufficiently scared away from the turbo-back solutions...
Old Jul 23, 2009 | 09:15 AM
ALTA_Jarid's Avatar
ALTA_Jarid
We are working to get the exhaust to fit PERFECTLY. We will keep y'all posted!!
Old Jul 24, 2009 | 04:44 PM
phillyMCS's Avatar
phillyMCS
Please get the exhaust done asap! I can't stand driving this quiet car any longer. :-)
Old Jul 24, 2009 | 09:06 PM
SprintA3's Avatar
SprintA3
The exhaust is done, just we're working on a solution for the brace. I think we may have it finalized next week. I'll post the temporary solution tomorrow. It isn't pretty, but it got us on the road for the time being.
Old Jul 26, 2009 | 09:46 PM
SprintA3's Avatar
SprintA3
Here is the current solution. As you can see, it isn't the most elegant way to solve this problem. We will be figuring out something permanent this week.
Old Jul 29, 2009 | 05:01 PM
SprintA3's Avatar
SprintA3
The problem will be assessed next wednesday. We are going to eliminate the V-Band clamp that is causing the issue and weld that connection.
As soon as there is an update, I'll post more info. Hopefully with the clamp gone, we will have a good deal more clearance for the cross braces.
Accessory Products
Aug 13, 2015 12:48 PM
Aug 13, 2015 12:47 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:59 PM
