MCS transmission trouble
Old Jul 21, 2009 | 05:43 PM
MINI-IZED's Avatar
MINI-IZED
I have a 04 MCS and the other day I got in and tried to shift into reverse and it wouldn't go in. I was able to get it in after some trial and error. I have found that if I slap the lever to the left, like normal, then let the lever move slightly to the right while pushing forward it will go into reverse. I have to do this every time I am shifting into reverse for the first time after stopping. If I sit and play with it, some times it will go in reverse like it is supposed to. This started a few days ago. Then today on my way home, I get off the interstate and tried to shift out of 6th and it was stuck, eventually I did get it out of 6th but when I got back on the highway it wouldn't go into 5th. It will shift fine in any of the other gears, including 6th, but it will not go into 5th. I have shifted through all the gears while driving and while stopped, with the engine running and with the engine stopped. Any ideas what the problem could be?
Old Jul 22, 2009 | 05:16 AM
03BRG's Avatar
03BRG
I would say the clutch slave has gone bad. CK to see if you are low on fluid if all seems fine with the clutch you could drain the tranny and look for metal in the oil that would tell you the tranny has a problem.
Old Jul 22, 2009 | 05:42 AM
jhiggs26's Avatar
jhiggs26
Sounds like shift cable malfunction to me.
Jeremy
Old Jul 22, 2009 | 06:04 PM
MINI-IZED's Avatar
MINI-IZED
I will check but I don't think slave cylinder is the problem, and I really don't want to find metal shavings in the tranny!
Ok lastnight I went for a short drive and tried "dry shifting" (shifting without using the cluch and rev maching) I was able to shift into and out of 3rd 4th and 6th. I did't try 1st or 2nd. When dry shifting it would easely go into gear once the engine rpms matched the vehicle speed.
Jeremy
Is there any way to check and/or adjust those?
Old Jul 22, 2009 | 07:01 PM
not-so-rednwhitecooper
Probably not a slave.
I would also say its a cable problem. Maybe one of the retaining clips popped off and the cable isnt being secured properly.
Try just shifting with the engine off, with the clutch engaged.
Old Jul 22, 2009 | 08:50 PM
MINI-IZED's Avatar
MINI-IZED
Engine on, engine off, clutch engaged, clutch disengaged, it just will not go into 5th. All the other gears are just fine, well, accept reverse. Has anyone taken these apart? Does anyone know of an exploded view of the gearshift mechanism or transmission?
Old Jul 22, 2009 | 09:30 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
If you end up needing a trans call us I got one.
WAY
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Sep 30, 2009 | 03:54 PM
blonda's Avatar
blonda
Did you ever find out the cause of this? My 05 is at the dealer as we speak for similar issue. They found metal shavings in fluid, said it could be syncros and want to replace the entire tranny
Old Oct 6, 2009 | 05:29 PM
MINI-IZED's Avatar
MINI-IZED
I haven't. I've just been driving around skipping 5th gear. I called the dealer and unfortunately they don't have any break downs on the transmission to get parts, all they can do is sell the complete unit. However he remembered ordering parts for a local auto shop that was able to give him part numbers for the internal parts. This shop is more local than the dealer (600 mi) however they are still a ways away (aprox 100 mi). I haven't had a chance to make the road trip yet. I also need to see if any closer shops would be able to do the work. Keep us posted, I would like to hear the outcome on you MINI.
Old Oct 13, 2009 | 12:57 PM
blonda's Avatar
blonda
Mini-Ized: Finally got the approval for warranty replacement. Here are the details here
https://www.northamericanmotoring.co...ml#post2897041
09R56
Nov 16, 2022 10:49 AM
eatsleepautox
Oct 30, 2015 06:46 AM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
PSIChocolate
Aug 13, 2015 12:46 PM
