R56 Tow Hook
Old Jul 21, 2009 | 01:47 PM
spinned's Avatar
spinned
Tow Hook
I am thinking about installing my tow hook to deter those that prefer to park by braile. Does anyone know where you can find a rubber grommet to go around the hole in the bumper so it will look more finished?
Old Jul 21, 2009 | 02:50 PM
quikmni's Avatar
quikmni
- Some hardware stores have a good selection of grommets.
- If you have a electronics parts store nearby, that is a good source. Probably not at Radio Shack but more like a Electronic Parts Warehouse.
- Electrictrial supply store. However some only sell large quantities.
- mcmaster.com (mcmaster-carr). Search for rubber grommet.
Old Jul 21, 2009 | 07:03 PM
rrcaniglia's Avatar
rrcaniglia
I took the plastic cover that you remove and dremel'd a hole in it. Very eary using a stone bit. Have to be careful to get the hole lined up correctly since the bumper curves. It needs to be a bit to one side.
Here is a pic. I used some touch-up paint to cover the interior edges of the hole. You'll note that my hole should have been a bit to the left, but it looks fine unless you're a true craftsman being mean.
Old Jul 21, 2009 | 07:04 PM
mini cooper mini's Avatar
mini cooper mini
Can you show us what you are talking about?
Old Jul 21, 2009 | 08:06 PM
spinned's Avatar
spinned
rrcaniglia do you knw if you can just buy the tow hook cover if I damage it beyond recognition?
Well the other posts have the idea. If I take out the tow hook cover on the bumper I was hoping to fit a rubber grommet around the sharp edge of the bumper hole. The same way electrical wires are installed through the firewall of a car. Here is a picture of regualr rubber grommets. But I want something to fit the square hole on the R56 Mini bumper. And then I will just run the tow hook through it.
Old Jul 21, 2009 | 08:09 PM
drewstermalloy's Avatar
drewstermalloy
Can't it do damage to your frame if someone actually hits it?
Old Jul 21, 2009 | 08:27 PM
zrowcool's Avatar
zrowcool
they'd have to hit the hook really hard to cause frame damage. that kind of impact would damage even more if the hook wasnt there.
Old Jul 21, 2009 | 08:31 PM
Oxybluecoop's Avatar
Oxybluecoop
I've seen tow hook covers still in the plastic for sale on EbayUK so you can probably order them as a single piece.
Old Jul 21, 2009 | 09:32 PM
spinned's Avatar
spinned
Here is another picture. You can see how the hole looks unfinished on the R56 (yellow bumper) after you install the tow hook.
Old Jul 22, 2009 | 04:19 AM
slinger688's Avatar
slinger688
Spinned,
How would you stop someone walking by from stealing it?
Old Jul 22, 2009 | 05:24 AM
mini cooper mini
I was thinking about mounting my plate there as well and wondered what to do about the square hole as well. Let us know if you come up with something GREAT.
Old Jul 22, 2009 | 09:40 AM
spinned's Avatar
spinned
I guess some guys use lock tight or teflon tape. I don't usually leave my car on the street for long so I figured it would be ok.
Old Jul 22, 2009 | 10:14 AM
Robin Casady's Avatar
Robin Casady
How is this going to stop them? The kind of people who park by braille are unlikely to notice it.
Old Jul 22, 2009 | 10:50 AM
djmcgill's Avatar
djmcgill
As 'RRCANIGLIA' noted, most MINIacs who are concerned with the appearance of the bumper have drilled out the existing cover. It looks much better than leaving the cover off.
As to the question by 'SLINGER688' regarding theft, someone interested enough would need to have wrenches available and be motivated enough. If your concerned, locktite and enough torque during install should keep the hooks in place. I have badges on the back of the "Ghost" and no one has ever messed with them. (they are VERY easy to remove.)
Old Jul 23, 2009 | 05:17 AM
33EJB's Avatar
33EJB
Those are aftermarket tow hooks, right? Because mine doesn't look anything like those. Mine is one piece, it doesn't have that folding part that forms the round "hook" like the ones pictured. Much more utilitarian (ugly, even?).
Mine's not as nice looking, but on the plus side it sticks out from the bumper farther - so anyone doing the "park by touch" thing would get a nice ding in their own bumper from the hook before contacting my bumper.
I'll put the hook on later and post a picture.
_________________________________________________
Old Jul 23, 2009 | 05:27 AM
djmcgill's Avatar
djmcgill
Those hooks pictured above are from 'OUTMOTORING.COM'. They add a nice touch, but are expensive.
Your standard hook, which is supplied with every MINI is very utilitarian.
Old Jul 23, 2009 | 05:28 AM
sir5150's Avatar
sir5150
On mine I machined a billet plate and engraved it to cover the hole and used a little locktite to help some one from just unscrewing it needs a wrench
Old Jul 23, 2009 | 07:12 AM
The-Only-One's Avatar
The-Only-One
On R53's make sure to get the threaded part shortened a little bit because (a) it sticks too far out and (b) the threaded part does not look good at all...
Old Jul 23, 2009 | 02:17 PM
spinned's Avatar
spinned
You should sell these. How do they stay in place?
Old Jul 23, 2009 | 03:10 PM
mini cooper mini
i'd be interested too, can i have mine in black?
Old Jul 23, 2009 | 04:59 PM
rrcaniglia's Avatar
rrcaniglia
How do they stay in place? I put some high strength LockTite on the threads and then adjusted the screw and nuts so the fixture gets hand tight while still about--oh, say 20 degrees from vertical. You know, maybe at the 4 or 4:30 position. Then I used a rubber mallet to tap it to a vertical position. I don't think it will be easy to remove.
Old Jul 23, 2009 | 09:24 PM
spinned's Avatar
spinned
I haven't pulled off the bumper cover yet because I didn't want to scratch it. Do you push it in or take a screw driver to it and pry it out?
Old Jul 24, 2009 | 09:47 AM
sir5150's Avatar
sir5150
I hold the plate in with a little clear silicone on the back side edge been on for over a year no problem. sorry only made two prototypes one for me and the other for a club member. a little powder coat you could make them any color. I made inserts for the rear fogs and they are polished too so stayed with the polished look for front.
Old Jul 24, 2009 | 02:17 PM
rrcaniglia's Avatar
rrcaniglia
They pop out so easily, I don't think you can scratch them if you exercise any care at all.
Old Jul 24, 2009 | 02:18 PM
rrcaniglia's Avatar
rrcaniglia
BTW, I really like your sig pic. The red just pops against that backdrop, which really emphasizes the specialness of the MINI. Good art.
