2009-2010 Season Autocross and driving events
For Hawaii
Autocross dates and rules-
http://www.sccahawaii.org/solonews.php
Entry Fee Update
Entry fee effective with 3/22/09 event:
SCCA member: $30
Non-member: $45 ($30 + $15 weekend membership)
The following are new event dates (all Sundays):
06/06/09 (Saturday – Annual Awards Banquet)
07/12/09
07/26/09 (T&T)
08/02/09
08/16/09
09/27/09 <-- Date changed from 09/20!!!!
10/04/09
10/18/09 (T&T)
11/01/09
12/13/09
01/10/10
01/24/10 (T&T)
02/21/10
03/07/10
04/04/10 (2009-10 Season Run-offs)
All drivers MUST drive in their assigned heat. If they do not, and a protest is lodged, a time penalty will be assessed for each valid run time. The normal penalty will range from 2 to 5 seconds, and this will be weather dependant. Please see the SCCA rule book for protests.
Remember also, that protests can also be if you suspect a car in your class is not following the rules for that class, running out of heat, being called for a DNF when you believe there was none, etc.
Entry Fee Update
SCCA member: $30
07/12/09
07/26/09 (T&T)
08/02/09
08/16/09
10/04/09
10/18/09 (T&T)
11/01/09
12/13/09
01/10/10
01/24/10 (T&T)
02/21/10
03/07/10
Lets look at the breakdown based on the last event-
1. BMW M3 (RWD)
2. Subaru WRX- STi (AWD)
3. BMW M3 (RWD)
4. Honda Civic (FWD)
5. Acura Integra (FWD)
6. MINI Cooper S (FWD)
7. Subaru WRX wagon (AWD)
8. MINI Cooper S (FWD)
9. Subaru Impreza (AWD)
Stephen N. has dropped out of SM and now drives a Miata
We could recruit a few more SM drivers in MINIs.
See
http://sccaforums.com/forums/1/334868/ShowThread.aspx
Quote:
STREET MODIFIED
- The SMAC feels that the prior proposal for SMF did not receive enough support to be considered for a national class
at this time. The SMAC would like to propose the following for a possible SMF provisional class for 2009:
- SMF would encompass ALL FWD cars under the current SM weight formula: 1550 lbs + 125 lbs/liter
- All SM rules will apply with the following exception:
- Cars running tires with a nominal width of 275 or less will NOT receive a weight break as stated in SM.
- FWD vehicles originally classed in SM2 add 100 lbs to min weights.
- This class would be a provisional class that will run with SM at nationals. SM-eligible cars will be eligible for and counted within SM for contingency, trophies, etc.
Submitted,
Erik Strelnieks, SEB representative
You can ask Curtis how he feels about this change.
Now that nationals have passed I can ask about SMF class as a subclass for SM at nationals- if they gave awards separately then we can ask about having it in Hawaii region.
Next Autocross is next sunday Sept 27
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
eatsleepautox
Oct 30, 2015 06:46 AM
