R50/53 Issues with lights not ligthing up on dashboard when turning key; then no ignition!
Hello,
I hope that someone on this forum can help me. I have been having issues with turning my 2004 Mini Cooper engine on in the last two weeks. I would turn the key all the way to the point where normally a bunch of lights show up on the dashboard, but most of them wouldn't light up. Then, when I keep rotating the key and try to start the engine, nothing happens. It would take me a few tries before eventually seeing the lights on the dashboard light up and then being able to turn the engine on.
I am thinking that something is going wrong with the ignition switch but I wanted to seek your opinion before bringing my Mini in for an expensive service.
Any ideas on what might be happening?
Many thanks,
Thomas
Many thanks,
Thomas
Hey Chase,
Thanks much for your post. I did look into the battery connections, tried to tighten them, and since then, I haven't experienced anymore the issue with dashboard lights not lighting up. I'll see if the "fix" works in the next few days and will post again to let you know.
Again, thanks very much for your help, I appreciate it!
Thomas
Thomas
Sure! You may want to make sure that all of the washers are where they belong on the terminal connectors. When I put mine back on, I got mixed up where they were supposed to be and they didn't tighten properly, giving me a similar problem.
-Chase
-Chase
get battery checked too
if it were me I'd dtop by AutoZone or the like and have the battery condition checked. Your charge may be dropping such that you are "on the edge".
Most major parts chains will check the battery for free.
09R56
Nov 16, 2022 10:49 AM
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
