Navigation & Audio OEM SIRIUS antenna base?
Old Jul 16, 2009 | 03:55 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Does anyone know the Part Number for OEM Sirius Antenna?
I am reffering to the older one that has the Sirius antenna intergrated into the black plastic/rubber base. Not the $29.99 "wart" magnetic sirius antenna that sells at Best Buy, but the older OEM base antenna. Any pics appreciated? Also, If the base is different can I use the guts in the older Sirius antenna and cover it with the newer non-sirius base cover? Any install tips for oem Sirius and Antenna Install?
I went oem one cause I HATEthe wires showing on my current sirius unit (aux, ant, & charger plugs) and I HATE having aftermarket non-oem do-dads, gadgets, electronics. So, no Blitz no DICE.
Old Jul 16, 2009 | 11:36 PM
howsoonisnow1985
OK maybe just pic and part number?
Old Jul 17, 2009 | 09:29 AM
Edge's Avatar
Edge
AdMINIstrator
Part number is 84110150524.
Installation PDF here.
Not sure if the antenna kit has since been discontinued or replaced with another part number though.
Old Jul 18, 2009 | 11:51 AM
hunter99's Avatar
hunter99
From what I understand MINI no longer produces the antenna base on 1st Gen cars with intergrated sirius receiver. I have a last week of Oct. '06 build and the sirius antenna is a black square that sits right behind the antenna base. It actually looks fine and is not really noticeable. It wires directly into the sirius unit in the left access panel.
Old Jul 19, 2009 | 03:50 AM
howsoonisnow1985
oem sirius base
Thanks I bought today at Concord MINI they had one in stock. It looks the same as mine but my 06 has a textured flat black and oem sirius is a shiny polished black base.
Old Jul 19, 2009 | 05:48 AM
hunter99's Avatar
hunter99
Wow, that was lucky. I know I checked into it about 6 months ago and there were none to be found and no longer being produced. Classic went looking for me. If what classic told me is true then you may very well have found one of the very last ones.
Old Jul 21, 2009 | 03:59 AM
howsoonisnow1985
By chance
Yeah I called MOMV and said they don't have I guess they're database search only does their BMW/MINI storage facilities not actual dealership stock. That was Concords last one accidently dropped by on saturday there for a MINI run, but run was sunday, so figured I check their parts dept. And got lucky. I know when I was looking for a start button panel for GP they told me there was none in the country turned out Morristown had 2 (not silver though) and Minspeed had several in Silver. I would try calling every MINI dealership in your surrounding area and Morristown.
Old Aug 5, 2009 | 07:03 AM
ninjamini's Avatar
ninjamini
Is it the same antenna connector as the retail antenna. I thought it was different.
Old Aug 5, 2009 | 07:37 AM
howsoonisnow1985
Yeah FM plug is different was gonna mention that on my please please help post but think no sound oem sirius is the real problem, then I can deal with making FM plug fit with bit from the old antanea.
blackie
Jan 18, 2017 09:57 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Dashdog
Aug 10, 2015 06:17 AM
