Suspension Squeeky 22mm Rspeed rear sway bar drives me insane! Maybe Energy Suspension bushings?
Old Jul 15, 2009 | 01:47 PM
alx873's Avatar
alx873
Hi there, I've checked all the threads on this issue, but nothing specific to my Rspeed 22mm rear sway that I got about 3 years ago.
So, I installed the bar by myself, and there were no noises for about 7 months. But once it started, it was so annoying. I would jack the car up and tried to stick grease everywhere around the fittings, but the problem with bushing is that it has no zerk fittings to inject the grease into the bushing. So the temporary fix of rubbing grease around the bushing only makes the squeak go away for weeks. The problem is that the grease doesn't go between the bar and the bushing without the zerk fitting there's no way to regrease the bar properly without taking the whole bar off again and regreasing the bushing like a new install.
Called Rspeed to see if they have any replacement parts with zerk--fittings. Was told that "sorry can't help you out."
VERY annoying.
Anyway, was hoping there was someone out there with experience with replacing the Rspeed polyurethane bushings with the ones from Energy Suspension ones with the zerk fittings? The one in 22mm? (http://www.energysuspension.com/pages/swaybbct.html)
Is it a direct fit?
[I just wanna take this squeaky bar out one time, and do it right once, and not have to worry about the squeak anymore. Thanks ahead for any help on this!]
Old Jul 15, 2009 | 09:24 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
This is exactly why I suggest the Hsport bars, no squeaks. And easy to get parts if need be.
I've fixed several Rspeed and other brand swaybars by replacing the bushings with the energy suspension bushings.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jul 15, 2009 | 10:59 PM
alx873's Avatar
alx873
Okay, so you're saying that I can just get the 22mm energy suspension bushing with the zerk-fitting, and slip that on, ya?
i'll do that next time the cars up on the rack. Thanks.
Old Jul 16, 2009 | 07:00 AM
Vendor
Yes, but the Energy suspension zerk is pointed up so you probaly won't be able to use it to grease.
Old Jul 18, 2009 | 03:26 PM
Mini_Crazy's Avatar
Mini_Crazy
Try a different greasing technique
Originally Posted by alx873
The temporary fix of rubbing grease around the bushing only makes the squeak go away for weeks. The problem is that the grease doesn't go between the bar and the bushing without the zerk fitting there's no way to regrease the bar properly without taking the whole bar off again and regreasing the bushing like a new install. ]
When I was using the RSpeed bar (switched to a 19mm), I had squeeks also. What worked for me to get lubricant into the bushings fairly easily, was to first disconnect the end links. Then you can rotate/slide the bar to one side and coat that side of the bar, slide it the other direction and coat the other side.
Regarding the lubricant, regular grease is not the best choice. There seems to be two schools of thought:
  1. Anti-seize (preferably copper-based, but aluminum-based is used also and is more readily available). Copper-based is what some Energy Suspension bushings come with.
  2. The blue-colored marine grease that is used to lubricate wheel bearings on boat trailers is highly recommended for use with urethane also. This stuff has a different base-stock than standard automotive greases.
I have used both successfully on different urethane bushings, but since anti-seize is so difficult to wipe off of anything, I tend to think it will stay put once you get it between your bushings & swaybar.
You can fix this.
ps. If you decide you want to switch to the Energy Suspension bushings, go with the the black ones. they have slippery-stuff embedded in the urethane (molybdenum if I recall correctly), while the other colors do not.
Old Jul 29, 2009 | 02:01 PM
alx873's Avatar
alx873
update: Energy Suspension Bushings won't fit
Hi,
So I bought a set of the 22mm Greaseable bushings from Energy Suspension. 9.5158G. The bushings doesn't fit because the flat part (where the bushing lays flat against the underbody) is too thick. Shaving it down would not be practical because then the bracket would not go over the bushing correctly.
What the HELL. Did you buy the wrong Energy Suspension Bushing? I need a slimmer bushing that fits around a 22mm. Anyone have any idea?
I think the Alta 22mm bushing and bracket might do the trick to make this Rspeed rear sway go squeak go away? (alta's have zerk fittings also)
Old Jul 29, 2009 | 02:11 PM
andyroo's Avatar
andyroo
Teflon tape under the bushings works wonders.
- andrew
Old Jul 29, 2009 | 02:21 PM
not-so-rednwhitecooper
Hi,
Shim it and get longer bolts?
Old Jul 29, 2009 | 08:37 PM
The_R1_Kid's Avatar
The_R1_Kid
How about drilling and tapping zerk fittings into the r-speed bushings? Just drill through the bracket and through the bushing material then tap the bracket for the zerk fitting. There isn't a whole lot of metal for the threads of the zerk but it doesn't need to be torqued down anyway.
Old Jul 30, 2009 | 06:06 AM
andyroo's Avatar
andyroo
Or just use teflon tape.....it's not very difficult.
- Andrew
Old Jul 30, 2009 | 03:03 PM
alx873's Avatar
alx873
- Andrew
So as to your teflon method. I assume you wrap it around the bare bar a little bit before you put the bushing around it with grease, then bolt the bracket down? Does this make the noise go around permanently? Just curious because seems like teflon tape wrapped around the bushing would be under a lot of twisting and friction, wouldn't the teflon tape just get ripped apart eventually?
Old Jul 30, 2009 | 03:06 PM
alx873's Avatar
alx873
Can't shim it at all because the problem is that it's already too thick to clear the flat part of the bushing where it sits against the subframe and the bar. Shimming the bushing/bracket would only make it thicker, not thinner.
Old Jul 30, 2009 | 03:44 PM
Mine fit perfectly. I just got them today from Summit. I used non grease able ones because the grease able ones never work, the grease just sits at the top of the bushing.
My bar is 25mm too, so its even tighter than yours is.
Old Jul 30, 2009 | 06:31 PM
andyroo's Avatar
andyroo
This is what i do with subarus and it works well.
- andrew
Old Sep 2, 2009 | 08:25 PM
alx873's Avatar
alx873
So far, Teflon + Grease has been working.
Hello, so i took the advice here and regreased using the super sticky stuff from energy suspension (they come in small one time use packets and they are clear/milky) and also wraped as much teflon around the bar as much as possible (i'd say about 6-8 wraps). It was very hard to wrap the teflon tape around flat because the bar was still sandwiched between the subframe and the body of the car when I was trying to wrap it. And without proper working room, the teflon tape would fold over on itself.
No matter, some folded over, but i kept wrapping it anyways. So far so good, it's been 2 months, and no squeeks. Lets see how this goes.
Thanks for the suggestions guys!
Old Sep 3, 2009 | 07:00 AM
andyroo's Avatar
andyroo
good to hear!
- andrew
Old Sep 10, 2009 | 10:53 PM
martinb's Avatar
martinb
When first installing the bar and bushings, I'd suggest removing any paint where the bushing will fit. The get some dry molybdenum disulfide powder (the pure stuff that makes a moly grease a moly grease) and burnish the rub the powder into the surface of the bar where you removed the pain and cleaned it thoroughly first. The, also rub and burnish the moly powder into the ID of the bushings. Moly powder is super fine and can get into the tiniest of pores. And remember, moly is a dry lubricant to begin with. Finally, go down to your local Honda motorcycle shop and buy a small tube of what they call Moly 60. It's a light grease with 60 percent by weight moly in it. It's normally used on the driving splines of the wheel and final drive on shaft drive bikes. It stays put and does a fantastic job of lubing. After all that, I'd be totally shocked if the bar ever squeeked again.
Old Apr 11, 2010 | 05:59 PM
dorkboy's Avatar
dorkboy
Hey, so I noticed the other day that my Alta bushings are deteriorating away, so my rsb is loose in the bushings. They have squeeked like hell right from the beginning and I have put a grease fitting and have greased them often. I need new bushings, and I like the sound of the Energy ones. Which's one are an "exact fit" setup? Or what else do you recommend?
Thanks,
Scott.
silence2-38554
Nov 12, 2015 09:39 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
