Suspension Evening out front camber, without camber plates?
Old Jul 15, 2009 | 01:06 PM
andyroo's Avatar
andyroo
Disclaimer: I have not even looked at the lower mounts on my new (to me) 2005 MCS.
I was wondering if anyone has developed a way to even out the front camber on the 1st gen Mini WITHOUT using camber plates to do so? IMO camber plates should be set the exact same way on each side, otherwise funky things happen to suspension geometry and the roll center. And i'm a sucker for a "perfect" alignment.
I also plan on going with IE fixed camber plates because i want the rubber and quality bearing and don't want more than 2 degrees of camber. I know my strut towers are at least a little deformed, so it's likely not even at the moment.
Since camber bolts are apparently not possible on the R53, there was some rumor the front subframe was "adjustable" in some way....any details?
Additonal side question: will the IE fixed plates "flatten" my already deformed strut towers or simply prevent any further deformation?
Thanks for the help!
- Andrew
Old Jul 15, 2009 | 01:16 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Hello Andrew, The IE Fixed plates will NOT always, if ever, be the same side to side no matter what you do to the towers. They will also not "fix" the tower only help stop the deformation. A hammer and 2x4 will help get the towers flat again.
If you want a perfect alignment you will need adjustable plates. You can get the adjustables to most any setting you want by moving the bolts around on the top plate.
Welcome to the "give and take" of MINI ownership.
Old Jul 15, 2009 | 08:41 PM
andyroo's Avatar
andyroo
Any details or a thread on the hammer + 2x4 method?
I'll probably be giving you a call next week for those IE plates.
- Andrew
Old Jul 16, 2009 | 03:08 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Straighten Towers
INSTRUCTIONS SEE PIC BELOW:
Old Jul 16, 2009 | 04:30 AM
Crashton's Avatar
Crashton
Dustin is right you will most likely end up with a slight variation L-R. On my car the IE fixed plates gave me 1.9-1.8. I see no issues with this. While not perfect it is much better than I had before the IE plate install.
Dustin, wow gotta hate that eye popping banner...
Old Jul 16, 2009 | 06:51 AM
andyroo's Avatar
andyroo
nice pic. so i just go "whack em mole" in my parking lot....hmmmm. i guess i'll do this after i put the plates in.
I'd be happy with a .1 difference side to side.
- Andrew
Old Jul 16, 2009 | 06:54 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Your results may vary. I have about -1.9 on one side and about -1.6 on the other. Even that amount of difference is insignificant from a handling and tire wear perspective. Even on the track.
W0TM8
Dec 19, 2019 07:50 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
