R56 Discolored/stained bonnet stripes
Old Jul 4, 2009 | 01:07 PM
BritBoy's Avatar
BritBoy
When cleaning Min today I noticed one of the white bonnet stripes had badly discolored. I tried cleaning it in case it as stained, but nothing would work. It appears as though the vinyl is actually discolored as if it had been heated in some way. Has anyone else experienced this problem?
Attached Thumbnails Discolored/stained bonnet stripes-img_0136.jpg
Old Jul 4, 2009 | 02:00 PM
Drillslinger's Avatar
Drillslinger
Yup, the swoop (i.e. U-Stripe) on my 06 R53 got so bad I finally pulled it off
I was told that the factory vinyl didn't have any protective coating so you need to keep it waxed up real well (same as the paint of course). It was too late for me so I never bothered. For me, the worst bit was the water spots/discoloration from the washer nozzles
Old Jul 4, 2009 | 02:07 PM
BritBoy's Avatar
BritBoy
Drillslinger, did they replace the stripe under warranty?
Old Jul 4, 2009 | 02:55 PM
Porthos's Avatar
Porthos
Ya my 07's bonnet stripes are all water spotted up. So when I get to Florida I am taking them off an putting new stripes on.
Old Jul 4, 2009 | 04:36 PM
Benibiker's Avatar
Benibiker
I've been keeping my waxed up so no problems here, mine are black though...
Old Jul 5, 2009 | 03:27 AM
Drillslinger
Hell no I asked but got shot down.
Old Jul 5, 2009 | 03:06 PM
krim's Avatar
krim
pulled mine off due to heavy discoloration. drove thru an errant sprinkler head and got sprayed. it's almost like the water spots got cooked into the stripe. nothing worked and off they went.
Old Jul 6, 2009 | 06:20 PM
BritBoy's Avatar
BritBoy
Seems like a few people have had water spotting, but no-one has experienced the discoloration that I have...Weird.
Old Jul 7, 2009 | 12:56 AM
Porthos's Avatar
Porthos
I think that the bonnet stripes don't look that great but, the Mini looks weird without stripes. I might even take the big leap and have them painted on.
Old Jul 7, 2009 | 02:38 AM
Drillslinger
Mine looked pretty much the same as yours, I just had it worse around the nozzles.
Old Jul 7, 2009 | 01:31 PM
sequence's Avatar
sequence
discolored or peeling stripes? they fall under warranty replacement, if yr. car is still under warranty. My black ones on my 05 were doing this, almost looked brown, and the dealer replaced them NQA.
water spots? Not a chance. Yr. best be is to "Klasse" them with Klasse All-in-One acrylic cleaner-polisher. Will help keep hard water spots and rogue Cosmoline from the washer jets from becoming big problems. Stripes can be high mtce if U know not what y're doing, like me and my 05. Now, with three coats of Klasse protecting them on my 09, it's a breeze
Old Jul 10, 2009 | 03:40 PM
BritBoy's Avatar
BritBoy
Just thought I'd post an update to the discoloration problem;
The dealer replaced the stripes free under warranty, but advised me they only do it once, as they know its a common problem. They recommended cleaning the stripes with water every couple of weeks and applying a non-abrasive polish.
Well, the original stripes lasted two years, lets hope with a bit of care that this set will last longer.
Old Aug 17, 2009 | 12:29 PM
vudugrl's Avatar
vudugrl
same thing happened to my poor car. it almost didnt look like water spots but chips on the stripes. i went to the dealer and they're going to replace them free of charge.
next time i'll keep my stripes waxed, dealer says this helps the life of the stripes.
Old Aug 18, 2009 | 06:55 PM
Topmini's Avatar
Topmini
mine have spots on them too from bird poo and from water stains also.
i have some matte black vinly i bought and thought that it would be good to make some on my own.
only problem is i dont know how to make cut it..
Someone told me that the strips are just straight, and that they look like they curve because how the cars bonnet looks.
i think that that bonnet stripes are curved in fact, but im scared that when i peel em off i wont be able to use em as a stencil to cut the new ones..
any ideas?
Old Aug 18, 2009 | 07:04 PM
Sketch's Avatar
Sketch
Take the stripes off, minis look better without them anyway
Before I took mine off I actually noticed mine had been just fine, I would assume because of the level of protectant and car care products I use on my car.
Old Aug 18, 2009 | 07:23 PM
glhboy's Avatar
glhboy
After taking them off, could you tell where they had been on the paint because it would be brighter underneath? I'd like to take mine off.
Old Aug 18, 2009 | 08:56 PM
Fly'n Brick's Avatar
Fly'n Brick
My stripes got spots all over them, looked horrible. I used a hair dryer to remove them and replaced them with new ones from Aesthetic Creations. Only took about an hour.
http://www.aestheticreations.net/
They went on with ease and look great. Just make sure you don't shed a hair and get it stuck underneath as you lay down the new strip. With the light just right, there it is.
My next project is to add boot stripes.
Old Sep 1, 2009 | 10:23 AM
blonda's Avatar
blonda
Mine have yellow spots all over them. I assumed it was bug or tree sap stains (just bought the Mini a few mos. ago), but maybe is burnt in water spots. I wish I had known the dealer "might" replace under warranty as I just had it in for service a couple weeks ago darn it. Hmmm....only one month left on my warranty. Maybe I'll give it a shot otherwise it looks like I may just buy new ones and replace them.
You all mention waxing. I always thought wax was bad for decals and caused them to deteriorate so I've always avoided getting wax on any decals on all my vehicles. Are the modern waxes safe now?
Old Sep 2, 2009 | 05:50 PM
naturallybuilt's Avatar
naturallybuilt
I cleaned mine today with tire whitewall cleaner that the autoparts guy recommended... Worked Great!
Old Sep 2, 2009 | 08:39 PM
blonda's Avatar
blonda
Cool I have to give that a try.
Old Sep 2, 2009 | 08:59 PM
jewitcher's Avatar
jewitcher
Dealer replaced under warranty.
Old Jun 28, 2012 | 11:52 AM
pmsummer's Avatar
pmsummer
Old thread, I know, but my 2009 Clubman just developed spots and discoloration. Guess I'll try and get them replaced under warranty BEFORE I try whitewall cleaner on them.
Old Jun 28, 2012 | 05:22 PM
jewitcher's Avatar
jewitcher
Dealer replaced ours under warranty
Old Jun 28, 2012 | 05:54 PM
pmsummer's Avatar
pmsummer
Did yours look like mine?
I'll add it to my growing list to get fixed by the dealer over the next 10 months (before my warranty expires): Warped hood scoop, wildly optimistic fuel gauge, passenger seat-belt/airbag sensor, wind noise from the sunroof... and cross my fingers.
Old Jun 28, 2012 | 06:15 PM
the matey's Avatar
the matey
I got my car without bonnet stripes and recently had them installed by dealer a few months ago, after I saw it when I came to pick my car up, I went to see the service advisor to thank him and tell him they look great, he said "glad you like them, there is a life time warranty on them just so you know." so I'm not sure what the deal is with the whole warranty thing.
Note: my car wasn't under warranty when they installed them too.
