R50/53 Aftermarket gas cap or mod?
Old Jul 1, 2009 | 02:34 PM
jdjeff58's Avatar
jdjeff58
I will be needing a third gas cap for my 06 MCS. I was wondering if there is a better cap on the market or a mod anyone has done to keep from throwing the check engine light. As it is, these caps barely seal when new. I've tried different O rings. I've tried wiping the area dry after pumping gas. They seem to have a limited life and I'd like to find a more permanent fix. Any ideas?
Old Jul 1, 2009 | 02:51 PM
Capt_bj's Avatar
Capt_bj
given that my 95,000 mile 02 S never had this problem
and the fact that you have changed the cap
I'd suspect the problem is NOT the cap
maybe the top of the filler neck?
or the sensor?
Old Jul 1, 2009 | 02:59 PM
jdjeff58's Avatar
jdjeff58
I replaced the fist cap and didn't have the problem again for about a year and a half. Seems like the second one lasted just as long. I put a slightly beefier O ring in the first cap and it didn't do squat until I replaced it with a new cap. I guess $22.50 every year and a half isn't too bad, it's just the annoyance factor that drives me nuts.
The other thing that starts to happen over time, the O ring will start to leave a black residue around the lip of the filler neck. That will throw the light. Once that gets wiped and dried, it will seal again and light goes out. I'm wondering if it's the Sunoco gas eating the rubber. That's all I use.
Old Jul 1, 2009 | 04:03 PM
otbiker's Avatar
otbiker
As part of the emissions system, the gas cap should be under the Federal mandated 80,000 mile emissions warranty. Check with your dealer...
Old Jul 2, 2009 | 05:25 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Hmmmm.... 2.5 years and 55,000 miles on my original cap and no issues...
Old Jul 3, 2009 | 06:34 PM
jbell's Avatar
jbell
do you use any octane boosters, seafoam, etc?
Old Jul 3, 2009 | 08:00 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
84,000 miles and no cap problems. Sounds like you have problems other then with your gas cap.
Old Jul 3, 2009 | 08:04 PM
jbell's Avatar
jbell
I've got 5:1 odds that his tank is not properly exhausting pressure from changes in heat. rather than going where it should, the expanding air heads up and busts the seal and trips the sensor. the gas fumes/vapor pressing upward eats away at your seal leaving the black residue.
thats just my guess.
Old Jul 4, 2009 | 05:20 AM
healey67's Avatar
healey67
Yeah I'm going to have to agree with the mass... 7yrs and 83,000miles and I still have the origional gas cap. You got other issues.
Old Jul 5, 2009 | 06:46 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
You definetly have some other problem. I've only replaced one cap in 5yrs.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jul 5, 2009 | 06:58 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I have been sworn to secrecy but I can't go on any longer....I must confess.
Bless me father....but we all have been taking turns swapping out our failed gas caps once a year for your lovely new one's....
Sorry about that -
boostedhaze
Jan 2, 2018 07:26 PM
mrjolliff
Oct 9, 2015 05:55 AM
nshannon29
Aug 25, 2015 10:42 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
