Will TPMS work with this wheel?
Old Jun 27, 2009 | 08:54 PM
accordselux's Avatar
accordselux
Attached picture shows the valve stem arrangement. Will TPMS work fine on here or will I have to run them without it?
Old Jun 29, 2009 | 09:10 AM
Alex@tirerack's Avatar
Alex@tirerack
Most TPMs isn't compatible with 90 degree valve stems.
Alex
Old Jun 29, 2009 | 04:50 PM
accordselux
Hi Alex-
If I don't use the valve stem, and instead use the barrel mounting point, do you carry a TPMS sensor that would work? I am planning on getting the Yokohama's off of tirerack to go with the wheels so if I could get TPMS from you it owuld be much easier.
Old Jun 30, 2009 | 07:38 AM
Alex@tirerack
All my stock compatible TPMS monitors are held in place with the valvestem. I dont have a system that will mount without using the valve stems, that will be Mini TPMS compatible.
Alex
penguinhomey
38
Jul 7, 2019 09:24 PM
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
nomar116
Aug 9, 2015 09:42 AM
