Broken supercharger
Old Jun 24, 2009 | 04:56 AM
bluesmini's Avatar
bluesmini
Broken supercharger
I think i broke my S/C. It felt like a belt break but when i got out to check it out the belt was still there and the water pump was working..... I had it towed to the dealerchip Monday night. It's Wednesday now and they might..... get to it today. I'll update with any new info.
Old Jun 24, 2009 | 06:35 AM
Crashton's Avatar
Crashton
I hope you are still under warranty.
Please let us know the outcome.
Old Jun 24, 2009 | 01:34 PM
03BRG's Avatar
03BRG
If the water pump is working the supercharger is also. it is driven off the back of the SC. Good luck hope you get it fixed without being to much of a pain.
Old Jun 24, 2009 | 02:02 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Yeah ^ .... I'm not sure what "felt like a belt break" means - but if the belt was turning and the water pump was turning, and the engine was running... did CEL come on? Did it just feel like you lost boost but otherwise the car still ran?
If so, could just be a bypass valve or a split IC boot...
Old Jun 25, 2009 | 02:31 PM
bluesmini's Avatar
bluesmini
well, good news. it isn't the S/C. It was the crank pully. I did replace my crank pully about 14 months ago with a newer (02-05) version. Yes it was used but i didn't think it was that used.
Instead of a $1600 S/C waterpump i'm only gonna spend $400 on a new pully. Still a lot of money but better than i thought it was going to be.
Back to my inital thoughts on it being the S/C. I've broken at least 5 belts at the track. the feeling i was talking about was a sudden loss of power and a few lights coming on. I then expected the water temp to shoot up as it does with the belt breaking. having done this several times in the past i knew to shut down the engine asap. after my sesson was done i got out and checked the belt and it was there..... i was supprised. i fired it up and putted back to my paddock spot. I thought i'd take it for a quick test drive to see if i'd even be able to get it home. That didn't go well. limp mode as soon at it got up to 3k rpm. I could reset it with a simple restart. What i thought had happened was i destroyed the gears in the nose of the S/C preventing any boost from happening. both rotors would turn because if one does the other has to but unwillingly. I knew the car wasn't overheating so the waterpump was going when i'd get in and rev it up is when my eyes couldn't see the belt not turning the S/C. Oh well. like i said at least it will be less than a grand to get fixed. I've heard the S/C's last about 100k miles and i'm less than 150 miles from that.
Old Jun 25, 2009 | 08:11 PM
Some Guy's Avatar
Some Guy
If you want your supercharger to last another 100k...
pull the unit off and change out the oil on the water pump side. That is all you have to do to make it last. (well, mostly, K-heuvo has a thread on this).
Old Jun 25, 2009 | 09:32 PM
Cadenza's Avatar
Cadenza
Congrats your S/C is okay.
Can someone explain why pulley cranks on Minis go bad?
Old Jun 25, 2009 | 09:38 PM
ddawson's Avatar
ddawson
The rubber hardens and starts to fall apart.
I went with a solid unit so it don't happen again.
Old Jun 25, 2009 | 10:23 PM
Cadenza's Avatar
Cadenza
Is the OEM pulley entirely made of rubber or just the front part?
Old Jun 26, 2009 | 03:28 AM
bluesmini's Avatar
bluesmini
I pulled my S/C off last may (paid someone) and did the oil change. My motor was being rebuilt so why not. This is my third motor.
Old Jun 26, 2009 | 01:30 PM
Cadenza's Avatar
Cadenza
3rd rebuilt? How many miles does your MC have?
Old Jun 26, 2009 | 06:10 PM
bluesmini's Avatar
bluesmini
this is my "third" motor. the second motor was brand new and because it blew 100 miles short of the warranty end. that happened at the VIR with numbers on the side, harness and R-cmpd rubber on the car when it got towed off. I had paid for the extended 4 year/50,000. It was worth it. That motor blew up the #4 piston a year later down at Roebling rd. Instead of a new motor i just had that block cleaned up at the machine shop with a slight overbore bigger pistons to fit the new size and while i was in there a cam. I got it tuned by Jan when he was in town last July. my request was to make it last, not squeeze all the juice out of it. So far so good. I'll be at Lowes motorspeed way this coming friday then VIR that saturday and sunday. Hopefully all is well for now.
elverado
Jan 18, 2022 02:51 AM
RobbyD
Jan 29, 2019 01:22 PM
Fordgt4
Oct 10, 2015 10:42 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
