MINI some times does not want to start
Old Jun 15, 2009 | 09:54 AM
MiNi_MaC's Avatar
MiNi_MaC
Ok, i tried searching but all i found was about dead batteries but mine is not dead im sure of that...
So this is the deal, from time to time my mini doesnt want to start, Ive noticed that this happens more during hot/summer days than during winter/cold, and ive also notices that this happens more when i turn the car on and off a couple of times in a short period of time.
Why am i sure that the battery is not dead? well my previus battery had a good charge but even though i still replaced it just to make sure it was not the battery what was causing the problem, and even with a new battery i still get the same problem.
what happens?... well i turn the key and i can hear the fuel pump working, the electronics work, lights work, but the engine doesnt crank.
I am thinking is the starter, maybe moisture gets in there during hot days or something, i dont think is the alternator cause the voltmeter has been showing the same voltage all the time, i would love to hear what you think guys...
Thanks!
Old Jun 15, 2009 | 09:55 AM
MiNi_MaC's Avatar
MiNi_MaC
Oh i forgot to mention: some times when it doesnt want to start i just wait five or then minute then i try again and it works lol... thnaks!
Old Jun 15, 2009 | 10:04 AM
Mattias
Sounds like a classic starter but there is also a starter relay switch. How it works is ehen you turn on the key to start the car the ignition switch activates the relay which then gets power directly to the starter... A defective starter and the relay can have the same symptoms. Depending on how acessible the starter connections are, when the car wont start when it is hot try and jump the starter directly from the battery (or the power source in the engine compartment that is used to jump the car on the S) if the starter works when you do this you know its the relay if it doesnt then you know its the starter.. Hope this helps..
Best regards,
Mattias
Old Jun 17, 2009 | 08:46 PM
Johnna's Avatar
Johnna
reluctant starter '05 MCS
I've started to experience the same starter issue myself. Like MiNi_MaC, I thought my battery was beginning to poop out (64,000 miles) so I bought a new one. Nonetheless, the problem persists.
My experience is that, occasionally, the starter doesn't engage on the first try but works on the second try - without any wait at all. It's summer here in Colorado but it hasn't been particularly hot, just rainy.
I haven't explored the starter vs. relay test as suggested by Mattias yet. I'll have to find them first. I'm hoping to discover some kind of loose connection that's easy to tighten up.
Anybody else having the same experience?
John
Old Jun 18, 2009 | 07:54 AM
MiNi_MaC's Avatar
MiNi_MaC
Johnna... i used to just take out the key and try again and it used to work for me too, but now that trick its not working for me anymore, thats why i just wait a couple of minutes then try again... I guess i am gonna have to start looking in to how to change the starter!
Old Jul 13, 2009 | 07:00 AM
Johnna's Avatar
Johnna
start problem solved .... misteriously
Odd but true. I took my car in for the 60K service. During the service, the tech found and cleared some security codes (sorry, I didn't get the numbers) Ever since the service visit, the starting problem disappeared. My car now starts on the first twist of the key - first time - every time.
Old Jul 13, 2009 | 10:58 AM
Victa's Avatar
Victa
i had the same problem. and it only happened on really hot days. it ended up being the starter relay switch which was replaced for $180 at the dealer since i am now out of warranty
Getrieben
Sep 12, 2024 07:03 AM
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
veevsato
Aug 5, 2015 04:42 AM
