225/45/15 on a 15x6.5 wheel?
Old May 28, 2009 | 12:07 PM
Dinan604's Avatar
Dinan604
Looking for some help here. This if for the track only and I'm getting a set of Toyo R888s in either 205/50/15 or 225/45/15 sizing. Am I able to run the 225s on a wheel that is 6.5" wide? I'm thinking it might be a bit too wide but I want to hear from the track gurus here.
Old May 28, 2009 | 06:39 PM
ChiliXer's Avatar
ChiliXer
wow with those sizes your ODs are significantly smaller than stock. Just seems more than would be optimal to me.
I think at 225 you will be rubbing on the side of the strut just slightly. Might be okay if you get your offset down to the 40mm or below range. Would fit on the R56 most likely.
Old May 29, 2009 | 05:10 AM
Alex@tirerack's Avatar
Alex@tirerack
225/45/15 has been squeezed down to 6.5 or even 6 inch wide wheels by Miata owners for years. It will tramline on the street, and the short diamter may look silly on mini. Being so short in my experience this size fits mini without rubbing.
Alex
Old May 29, 2009 | 09:19 AM
Dinan604's Avatar
Dinan604
Ah it's okay guys, managed to find a 15x7 ET35 wheel at a good price that'll fit my 225s perfectly. Thanks for all the help!
Old May 29, 2009 | 12:07 PM
ChiliXer's Avatar
ChiliXer
Yeah probably should be okay with the 35 offset
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
