R56 Halogen Replacement Bulb Options
Old May 24, 2009 | 08:56 AM
rrcaniglia's Avatar
rrcaniglia
Am replacing my crashed MINI and considering not re-ordering the xenon package. Didn't like the illumination cutoff effect. However, have been told that the halogens are 'dim'.
Is there any option for bigger/better/brighter halogen bulbs than come from the factory? The ads on the web are full of promise, but you can't trust that.
Old May 25, 2009 | 08:03 AM
gaffer's Avatar
gaffer
I replaced the dims on my '05 with Sylvania Silverstar Ultra halogen bulbs. You can catch them on sale sometimes at places like Autozone, etc. I really like the whiteness of the light. I haven't replaced the ones on the '09 yet.
Old May 25, 2009 | 08:23 AM
toolazyforalogin's Avatar
toolazyforalogin
Don't get the Silverstars since they are only rated for 350 hours. Pick yourself up a set of PHILIPS X-TREME POWER 9008/H13
Info : http://www.lighting.philips.com/in_e...ghting&lang=en
Buy: http://www.bulbs.com/eSpec.aspx?ID=1...egory&RefId=13
Old May 25, 2009 | 09:21 AM
Wolfeee's Avatar
Wolfeee
I replaced mine with Luminics Ultra White...and did not like them at all...I felt that it illuminated the enviornment..just not directly in front of me and I felt that I was struggling to see the road... I just switched back to the stock bulbs this morning...
Old May 25, 2009 | 09:39 AM
futuremini's Avatar
futuremini
PIAA is the brand I am running and I am very happy with them.
Old May 25, 2009 | 01:18 PM
rrcaniglia's Avatar
rrcaniglia
Thanks, folks. Tuesday I'll order the new MINI and will not do the xenons since several of you indicate there are good halogen bulbs out there.
Now, what should I spend that extra $500 on?
Old May 25, 2009 | 02:10 PM
JudgeS's Avatar
JudgeS
PIAA's are way over priced for what they are, I would go with the Silverstars for simple replacements.
Old May 25, 2009 | 02:18 PM
ngweibing's Avatar
ngweibing
i sued sylvania and like it so far
Old Sep 23, 2009 | 06:22 PM
dlr328's Avatar
dlr328
how about the Luminics Titanium whites? They are 60w bulbs, do you all think that using these will affect anything?
Old Sep 23, 2009 | 06:31 PM
ricbow's Avatar
ricbow
i have phillips x treme 9008/h13 bulbs... love em
Old Sep 23, 2009 | 06:46 PM
redduc's Avatar
redduc
I just installed these in my headlamps and fogs. They look great, give off a decent amount of light and don't turn my headlamp housing "rice blue" when they are off. Much better than stock.
Old Sep 23, 2009 | 06:50 PM
dlr328's Avatar
dlr328
sorry, they are 65W bulbs, not 60W. Will that affect anything? would they be ok using the factory harness? any melting issues with a 5 watt difference? Thanks for the reply...
Old Sep 23, 2009 | 07:02 PM
redduc's Avatar
redduc
I'm not using an upgraded harness, but have only had the lights for 3 days. I would be interested to hear if any other NAM members think this is an issue.
Old Sep 23, 2009 | 07:04 PM
dlr328's Avatar
dlr328
have you noticed anything in the housing? any melting or anything like that? hey thanks for responding, I am just curious and don't want to burn the housing...
Old Sep 23, 2009 | 08:12 PM
redduc's Avatar
redduc
I checked their website and they do recommend the use of a heavy duty harness.
Old Sep 24, 2009 | 08:34 AM
redduc's Avatar
redduc
Harness ordered, better safe than sorry.
Old Sep 24, 2009 | 01:34 PM
redduc's Avatar
redduc
I went and checked the car today and there is no visible sign of heat damage. I am going to install the heavy cables anyway (only $37.00) for the extra insurance. I really like the look and the light output of these bulbs.
Old Sep 30, 2009 | 03:40 AM
dlr328's Avatar
dlr328
the only thing that worries me is that the bulb is a little shorter than the factory bulb...if you hold the factory bulb next to the luminics one, you can see the luminics is a little shorter. So the bulb does not sit inside the little housing inside the light. Wonder if it will cause damage....
Old Sep 30, 2009 | 05:39 AM
markusw's Avatar
markusw
How many hours are the PHILIPS X-TREME POWER rated for? I can't find this information anywhere.
Old Sep 30, 2009 | 09:05 AM
nickminir56's Avatar
nickminir56
This is what I found online:
http://forums.nicoclub.com/zerothread/305628
Here's the comparison of these bulbs to standard and high-performance 9005
and 9006 bulbs. A "+50" would be a Philips Vision Plus or GE Night Hawk. A
"+80" would be a Philips Xtreme Power.:
Low beam stock: 9006, 12.8V, 55W, 1000 lumens, 875 hours
Low beam compare: 9006+50, 12.8V, 55W, 1090 lumens, 300 hours
Low beam compare: 9006+80, 12.8V, 55W, 1120 lumens, 275 hours
Low beam new: HIR2, 12.8V, 55W, 1875 lumens, 875 hours
High beam stock: 9005, 12.8V, 65W, 1700 lumens, 320 hours
High beam compare: 9005+50, 12.8V, 55W, 1830 lumens, 175 hours
High beam new: HIR1, 12.8V, 65W, 2530 lumens, 320 hours
Problem is they seems to forget Philips Xtreme Power is HIR bulb:
From Autoexpress's famous H4 bulb test:
The previous highest output of an H4 bulb (+50% type) was rated at 107 between 50-75m (Halfords Super Brilliance, followed closely by Philips GT150 Power2Night at 102, and Philips Vision Plus at 98). The new Philips X-treme Power H4 (+80%) was rated at an amazing 146, and won the Accessory Of The Year award from Auto Express (a UK company that's done many bulb tests in the past). All bulbs were rated at 55W, safe for OEM applications.
Philips X-treme Power is a new type of halogen bulb, HIR (Halogen Infrared Reflecting). That means it has a reflective coating that makes use of wasted infrared light, reflecting it back at the filament and making it burn more efficiently, allowing more light output than any standard halogen/"xenon" halogen before it (especially the ones with colored coatings). The bulb also has a refined design, with smaller glass casing for higher pressure and improved filament geometry (placing of the filament(s) in relation to the reflector/projector, where most bulbs fail). This captures much of the stray light of previous designs and directs it back at the road where it belongs. It's unconfirmed, but the thin blue strip seems to be for short range lighting due to its position, while medium and long range get the full illumination of the clear portion. The difference in color isn't noticeable on the road.
My point:
Philips Xtreme Power is in theory an improvement in term of life expectancy among usual high output class. But only time will tell how long it gonna last on my car (12th month here) .
Performance wise it's very good. When I drove the loaner with stock bulb the other day, it made me double check the headlight switch twice at night.
Old Sep 30, 2009 | 10:29 AM
markusw's Avatar
markusw
Thanks, nickminir56!
Old Dec 13, 2009 | 09:26 AM
Matty0500's Avatar
Matty0500
Does anyone know where to find the Philips X-Treme power 9008/h13 bulbs to buy in canada? bulbs.com won't ship internationally unless it's over $100, and i can't seem to find any online vendors that will ship here.
Old Dec 13, 2009 | 01:23 PM
rrcaniglia's Avatar
rrcaniglia
I've got a stock MC with standard harnesses, etc. Can I safely replace the stock bulbs with the Philips X-Treme Power series?
Old Dec 13, 2009 | 02:01 PM
jcauseyfd's Avatar
jcauseyfd
rr, I have the Phillips X-Treme in my MCS. About six months now with the standard wiring. I wouldn't think there is any difference in the harness between an MC and an MCS.
Matty, if you can't find a solution and no one closer who can help you, pm me and I'll see if I can help out.
Old Dec 13, 2009 | 02:52 PM
richardsperry's Avatar
richardsperry
You are absolutely insane not to get the bi xenon headlights.
