Suspension Wilwood Brakes
Old May 21, 2009 | 11:13 PM
silversmoke06's Avatar
silversmoke06
Wilwood Brakes
Is there anyone out there that has the factory R98 wheels on a Set of 12.2 Inch brake kit.
Or knows if this is possible. What im looking for is the back spacing...
Hopefully someone can help.
Old May 22, 2009 | 12:06 PM
silversmoke06
Please Help!
Old May 22, 2009 | 12:15 PM
meb's Avatar
meb
If you know the offset and wheel width you should be able to calculate the back space, yes?
Which Wilwood Kit...meaning which caliper? DynaPro?
Old May 22, 2009 | 12:52 PM
toddtce's Avatar
toddtce
http://www.wilwood.com/PDF/ds490.pdf
Old May 22, 2009 | 08:29 PM
silversmoke06
Thanks todd but that still dosent help me answer my question.
As far as I can tell it wont fit. Thats why I dident call you back.
and the 12.2 inch kit.
I dont know the width or the backspacing im gonna go check on MotoringAlliance.
All it says is its a 7" wide wheel.
Old May 23, 2009 | 05:26 AM
chuckt's Avatar
chuckt
Assuming you have one of these R98 wheels, you can easily measure it up per the wheel clearance diagram included in the PDF that Todd provided.
Old May 23, 2009 | 09:15 AM
silversmoke06
I have them on my car, I would like to keep the stock wheels for as long as possible
Yes i know he sent me the diagram, However im unsure as to if its in inches or cm...
Im guessing Inches?
Though i may have them on my car im a total noom as to how to check for this.
Im thinking about a way to do it and seem to be lacking?
Old May 23, 2009 | 10:29 AM
chuckt's Avatar
chuckt
LOL, it's in inches & millimeters. You might want to ask the shop you plan on using for the install, to check the wheels for fitment.
Old May 24, 2009 | 11:24 AM
silversmoke06
Test
Old May 24, 2009 | 01:59 PM
onasled's Avatar
onasled
Old May 25, 2009 | 05:11 PM
bean's Avatar
bean
onasled: quit showing off your high tech measuring devices!
Old May 26, 2009 | 04:41 AM
nascar mini's Avatar
nascar mini
If the R98's are 17'' and 48et as i suspect, they'll work fine. I have 17''R90's(48et) on my Wilwood 12.20 set up with the DynaPro caliper with no spacer needed.
Bill
Old May 27, 2009 | 07:19 AM
silversmoke06
Turns out they wont fit.
I drove to agoura hills to see if they would, Alas they would not.
Onasled, thanks for nothing.
Nascar mini. thanks though.
Old May 28, 2009 | 03:19 AM
nascar mini
When you say ''won't fit'' what does that mean,wheel rubs cailper or.....? If so,just add a 5mm spacer.The BBK,Dynapro caliper?Wheels are 17'' aren't they,as on my install instructions say 12.2 rotor must use 17'' wheel.This project is really not that hard if you have all the necessary info.Wheel size and et,rotor dia and Caliper to be used.Also,i guess you figured out you need to eliminate the ''backing plate''after you remove oem rotor.Let me know if i can help,i've done it several times.
Bill
Old May 28, 2009 | 08:16 AM
//MZero's Avatar
//MZero
If the 13" kit fits behind my R99's without a spacer, than I'm sure you can get them to fit behind the R98s with a 5mm spacer...you aren't trying hard enough.
Old May 28, 2009 | 10:01 PM
silversmoke06
Nope it needs something along the lines of a ten mill spacer Rustyboy155 and i checked it out.
I would rather just be paitent and buy aftermarket wheels and get rid of these boat anchors.
Old May 30, 2009 | 08:17 AM
toddtce's Avatar
toddtce
FWIW, I put up a one time special offer on a Silver 12.2" DP kit. Standard factory kit with some extras included as part of the deal. If you know anyone looking for a bargain:
$850 to your door.
Old Aug 22, 2009 | 02:16 PM
silversmoke06
are you still doing this
Damnitryon may want it.
Old Aug 22, 2009 | 02:26 PM
toddtce's Avatar
toddtce
No longer have the DP silver kit. For silver I have only a larger 13" FSL kit.
For the smaller 12.2 kits...I do have a blue package.
Old Aug 27, 2009 | 08:57 PM
searocko's Avatar
searocko
Just put on this very kit and my R98s work with a 5mm spacer.
Old Aug 28, 2009 | 12:00 AM
silversmoke06
Its a moot point now.
I tryed it on a car. I wasent comfortable with the amount of spacer needed.
i went in a diffrent direction with my money
Im building a motor.
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
