R50/53 Rough idle after pulley upgrade
Old May 17, 2009 | 04:27 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I had a 15% pulley installed along with upgraded plug wires at MOTD. After I replaced the std. NGK plugs with the new Brisk plugs ( a bit cooler plug), the car now idles a bit rough and seems to skip a beat at idle, while also stumbling a bit when cold. I have read that a new coil pack MSD or Screaming Deamon has helped resolve these types of issues. Before I drop close to $90 on a new coil, is there any feedback that this is the correct path, or am I better off to go back to the original plugs that gave me no problems on the 1,000 mile ride back from NC.
Old May 17, 2009 | 04:39 PM
ScottRiqui's Avatar
ScottRiqui
Double-check that you used the correct Brisk plugs (one range colder than stock, max), and that they're gapped properly. I wouldn't start off by throwing in a new coil pack, because the factory pack is a pretty capable unit. There are quite a few MINIs running around on the factory coil pack & wires that are modified *way* beyond a simple 15% supercharger pulley.
Old May 17, 2009 | 04:57 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I verified that the "DR12S" Brisk Plugs are the ones recommended for use w/ 15% or > pulleys via Alta's Web site. The gap was set at .028 at the MOTD, but I did not verify that when I put them in when I returned home. It was suspected that my coil had a hot spot on #3 due to some discoloration of the lead. I ran the stock NGK's with the new wires and original coil on some pretty spirited drives on the Dragon and then all the way back to NH at 80 mph with no problems. I actually got 1.5 mpg BETTER gas mileage with the pulley and new wires then on the way down.
Any feedback on the preferred gap for those type of plugs? I will try resetting the gap to see if that clears things up before going back to the original plugs to see if that corrects the issue.
Old May 17, 2009 | 05:01 PM
AutoXCooper.com's Avatar
AutoXCooper.com
HI Jim, I recall our visit at MOTD and we encouraged you to replace the coil with an OEM before installing the BRISK plugs due to that #3 hot spot. Please out the NGK back in until the coil is replaced. I encourage the OEM or OEM replacement coil.
Old May 17, 2009 | 05:35 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
Dustin,
I came away thinking that a coil upgrade was necessary. My bad. I figured if an OEM coil was servicing the NGK's ok, then an upgrade was needed to handle the upgraded plugs.
Old May 17, 2009 | 05:39 PM
ScottRiqui's Avatar
ScottRiqui
Originally Posted by JIM_GRAHAM
Dustin,
It's not really the new spark plugs that would cause the need for a hotter coil pack - it's the increased dynamic cylinder pressure from the smaller supercharger pulley. With some cars that have marginal stock coil packs, the increased cylinder pressure can "blow out" the spark and cause the air/fuel mixture not to ignite.
Fortunately, the OEM MINI pack is more than capable of working with the increased pressure. In fact, there are quite a few MINIs out there putting out 250 or 300 horsepower with the OEM pack and wires.
Old May 17, 2009 | 08:23 PM
MrCooperS's Avatar
MrCooperS
Moderator
According to Alta it's DR12S...
According to Jan (RMW) it's 14LGS...
Old May 30, 2009 | 11:35 PM
ZippeeGear's Avatar
ZippeeGear
I'm experiencing the same problem but worse
I recently had my pulley changed to a 15% pulley, at the last AMVIV 6 car show in Las Vegas. They told me that the spark plugs, pulley and belt were all changed. Since then, my car has a rough idle at times and worst of all, from 2-3K during acceleration, my car hesitates very badly. I read somewhere that it could be caused by my OEM coil pack and/or plug wires, which seem to be all original since 2003. Any advice on this subject to help me fix this hesitation problem? Any help would be greatly appreciated.
Old May 30, 2009 | 11:45 PM
k-huevo's Avatar
k-huevo
Plug wires, but you also should pull the plugs and varify correct gap. Before putting the new wires on clean the coil terminal posts and apply dielectric grease.
Old May 30, 2009 | 11:55 PM
ca$per's Avatar
ca$per
K-huevo,
how do you know the correct gapping for the plugs? and how to adjust?
thanks
Old May 31, 2009 | 09:27 PM
ZippeeGear's Avatar
ZippeeGear
Update
I didn't know the proper gap for my plugs so I haven't attempted that yet. I'm assuming that the guys from AMVIV 6 had pre-gapped my plugs prior to installing them. However a few weeks ago, I had done what you advised me, about pulling off my plug wires from the coil pack and immediately noticed that all 4 contacts of the coil pack had some moist rust on each of them. I took some rubbing alcohol and attempted to clean off the rust. I then took some 400 grit sandpaper to scrub off the remainder of the rust. Next I took some dielectric grease and placed it into the boot of the wires and on the coil pack.
I test drove it right after and my car was driving 100% better than it was. I was shocked at how hard the car pulls at the 2-3k rpm range. This fix lasted for about 10 days, then I noticed in very hot weather my car progressively started to feel like it did before. I haven't changed my plug wires yet or the coil pack. I think they are both the original since 2003. Now my car runs like crap again.
Do you think that either my coil pack or plug wires could be faulty? How can I tell?
Old Jun 1, 2009 | 02:39 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I have read that the coil terminals are prone to corrosion. I was told to get an OEM coil which priced out at $115 + shipping, when I looked, so I purchased (from OutMotoring, they had it in stock when I called and shipped that day):
31732M 100-025Screamin Deamon Ignition Coil Pack $84.95 Subtotal: $84.95 Shipping cost: $16.70 Total: $101.65
This has addressed the rough idle and skipping problems. The instructions stated to set gap at .065 +/- (I am not reading them at the moment) which I have not done yet. I still get a brief stumble while the engine is cold but it goes away in a couple of minutes when the engine warms up. I am going to experiment with the gap to see if that goes away soon.
Old Jun 1, 2009 | 02:42 AM
jdjeff58's Avatar
jdjeff58
same mods, same issues
JIM_GRAHAM's Avatar
JIM_GRAHAM
You should e able to pick up a gap ring/tool or a set of feeler gauges at a local auto parts store.
As far as the gap, that is plug/car specific and you will have to do some research depending on what you have.
Originally Posted by ca$per
K-huevo,
thanks
Old Jun 1, 2009 | 05:53 AM
NOTDULL's Avatar
NOTDULL
My $.02
Stock plug wires are very good but at $30 each (quoted by the dealer) not the set, it pays to use aftermarket if needed.
I have found that with extreme care in removing and replacing the stock (or aftermarket) wires, some damage does occur each and every time.
I would replace the wires and all the other issues may be taken care of.
Old Jun 1, 2009 | 08:24 AM
ZippeeGear's Avatar
ZippeeGear
I'm not sure what to buy?
I noticed that some recommendations were to replace my OEM coil pack with either the screamin demon or msd? Also what are the best plug wires to go with? Does this hessitation definately have somethin to do with my coil and wires?
W0TM8
Dec 19, 2019 07:50 AM
blackie
Jan 18, 2017 09:56 PM
Marco Guardado
Sep 15, 2015 01:22 AM
Aug 21, 2015 10:41 AM
