R50/53 Serpentine Belt change?
Old May 16, 2009 | 11:16 PM
four_ari's Avatar
four_ari
My g'f has a 04 mini non s model that just had the tension pulley replaced under her extended warranty. They wanted an extra 75 for the belt. 1St question should the extended warranty cover the belt?
Is there a diy guide to changing it.. it looks really tight in there? i have read allot about the belts on this forum and wanted to know what is the correct belt number for her car. non oem would be better and cheaper.
thx
4ari
2003 BMW M3
Old May 17, 2009 | 07:46 AM
buzzsaw's Avatar
buzzsaw
There is a serpentine belt replacement DIY link on our DIY section that might work.
Old May 17, 2009 | 08:35 AM
ea6b607's Avatar
ea6b607
75 seems about right. I jsut had the belt replaced on my s two days ago. Mini was gonna charge $55 for the belt alone but i found it NAPA for under 20. Cost me 50 on top of that to have my mech replace it. From what I can tell in the Haynes Manual the non s should be easy enough to change without special tools and a mechanic.
Old May 17, 2009 | 10:04 AM
four_ari's Avatar
four_ari
I cant seem to find that link? Do you have a direct link?
Old May 17, 2009 | 10:23 AM
buzzsaw's Avatar
buzzsaw
Try this: http://www.metroplexmini.org/forum/s...ad.php?t=26456
Old May 17, 2009 | 11:41 AM
healey67's Avatar
healey67
Thats ridiculous!! They have the blet off anyways to change the tensioner. You should have just paid for the price of a belt and thats it. $75 is alot the a belt. ----rip off---
Old May 17, 2009 | 01:27 PM
four_ari's Avatar
four_ari
thats why i told the dealership to put the old one back on. imagine the face of the service guy when we heard her say nah put the old back on. lol..
thanks guys for the help.
4ari
Old May 17, 2009 | 01:53 PM
Fastlane's Avatar
Fastlane
I just changed the belt on my 06 non-s about a month ago. Super easy job. The dealer wanted to charge me $130 to replace mine! Honestly, with the belt costing $45 from the dealer (which is rediculous...) and then $90/hr labor, it's probably pretty average. I said "no thanks", though.
Get the belt from NAPA....it's in the $20 range. I ended up having to get one from the dealer since my friendly NAPA store ordered the wrong one and I had already taken the old belt off before I realized it...had to hop in another car and head to the MINI parts counter and shell out the $45.
Anyway, it's very easy to do. Just like in one of the links above, remove the front passenger wheel, remove the fasteners to loosen the wheel well cover and pull it back. I did not pull it forward, but rather pulled it back (towards the door) and hooked it behind the brake drum. It's very flexible and will just stay there. Also, turn your front wheels to full right lock...it will buy you some more space.
There is a square hole in the tensioner assembly that is pretty much a perfect fit for a 3/8" ratchet to fit in. It's tight, so you need one that is low profile. I just used my craftsman ratchet and had to reach down with a screwdriver to push the button on the back to get it to release from the hole when necessary...it worked o.k.
Anyway, spin the ratchet around until it is pointing basically straight forward towards the bumper or maybe a bit upwards and that will give you the angle that you need to pull the tensioner up.
On the tensioner, there is a little place where, when pulled up (loosening the belt) you can stick something in it to hold it up and out of the way (compressed). Someone on here suggested taking a 1/8" drill bit and bend it....I looked all over the workshop for something to stick in there and ended up taking one of my straight hooks from my tool peg board behind my workbench. Reached down with a pair of long needle nosed pliers and stuck it in the hole. Worked great.
At that point, you just reach in the wheel well and take the old belt off....put the new one on....pull up on the tensioner and pull out whatever you had stuck in it to hold it up. Put the wheel well back to gether and you are done. Simple!
Do it yourself and save some cash.
Good luck!
Old May 25, 2009 | 09:22 PM
four_ari's Avatar
four_ari
Good luck!
thanks this worked best..
I was able to remove the belt and replace it with another one. After i buttoned everything up, I started the car and the belt squealed really bad. I just went back to using the old belt that had no cracks. It only has some wear on the top of the belt. Should i have used Serpentine lube?
your write up was 100% spot on..
Old May 26, 2009 | 07:27 AM
Fastlane's Avatar
Fastlane
hmmmm. Not sure. I didn't get any noise after I did mine. Did you compare the old and new belt to make sure they gave you the right one? You shouldn't have to put belt conditioner on a new belt, I wouldn't think.
h0micide
Aug 27, 2015 09:17 PM
h0micide
Aug 25, 2015 12:19 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 17, 2015 07:15 AM
FLYM1N1
Aug 16, 2015 01:17 PM
