R56 Key Fob Slot Removal?
Old Apr 30, 2009 | 11:16 PM
Sketch's Avatar
Sketch
So im in the process of removing all of my colorline trim (switching colors), and I have all the pieces out except the trim that holds the key slot. I got the colorline trim unscrewed from the dash board but how do I unplug the key slot/engine start holder so I can mount it into the new trim piece?
Cheers!
Old Apr 30, 2009 | 11:23 PM
Oxybluecoop's Avatar
Oxybluecoop
If you have the colorline trim piece that holds the key fob loose then turn it around and there are three tiny Allen screws that hold the key fob slot to the trim piece.
Old May 1, 2009 | 12:08 AM
Sketch's Avatar
Sketch
Hey so I have the trim in my hand but im not seeing the screws
Old May 1, 2009 | 12:17 AM
Oxybluecoop
Did you pull off the plastic trim that the fob snaps into?
Old May 1, 2009 | 12:32 AM
Sketch's Avatar
Sketch
Oh no I didnt, im nervous that I will break something. Does it just pop off or is there more to it?
Old May 1, 2009 | 12:42 AM
Oxybluecoop
It just pops off. There is a clip on each side. You have to take that off in order to remove the fob reader from the trim.
Old May 1, 2009 | 01:32 AM
Sketch's Avatar
Sketch
Awesome thanks Oxy Blue! After popping the front part off it was a piece of cake
Old May 1, 2009 | 06:38 AM
pxtech's Avatar
pxtech
what color is your trim now and what color are you changing it to?
Old May 1, 2009 | 03:09 PM
Sketch's Avatar
Sketch
I have dark grey right now, changing it to rooster red.
Old May 3, 2009 | 11:13 AM
Kirkz24's Avatar
Kirkz24
Post some pictures when your all done. Would love to see it.
Old May 3, 2009 | 05:58 PM
VicSkimmr's Avatar
VicSkimmr
Ah man I'm glad you posted this.
Old May 3, 2009 | 06:23 PM
SaltNPepa's Avatar
SaltNPepa
Sketch
I want to take mine off to paint it blue if you have any directions or pictures of the removal of the color line parts it would be great.
Old May 3, 2009 | 06:33 PM
Oxybluecoop
Here's a writeup of how to retro the chrome line interior. Basically it's the same procedure just a few more screws to remove and the speedo doesn't need to be removed.
How Too.pdf
Old May 3, 2009 | 08:42 PM
clayvt's Avatar
clayvt
just curious...how much did the rooster red trim pieces cost?
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
jeremy_reyes94
Aug 26, 2015 10:10 AM
greekzilla
Aug 23, 2015 03:44 PM
coachvminis
Aug 17, 2015 01:42 PM
clintmeister
Aug 12, 2015 11:11 AM
