Suspension Longer 14mm wheel bolts in black?
Old Apr 9, 2009 | 06:31 AM
KrautHammer's Avatar
KrautHammer
Longer wheel bolts +5 mm exist in the older 12 mm size but I can't find any in 14 mm.
Don't want caps or studs. Any sources?
BTW are our bolts ball or cone seat?
Old Apr 9, 2009 | 06:48 AM
slinger688's Avatar
slinger688
Did you try TSW.
http://www.txwerks.com/servlet/Categ...rt=17&total=70
btwdriver's Avatar
btwdriver
I think that you will find getting the 14x1.25 bolts for the R56 quite difficult. I know you said that you don't want studs, but it think you will find that to be your best option. I have a set from TSW and love them. (they come in black) Here is a link: http://www.txwerks.com/servlet/Detail?no=182
The R56's have a 60 degree taper cone.
Old Apr 9, 2009 | 07:15 AM
quikmni's Avatar
quikmni
I searched and searched and did not find any black 14mm lug bolts when I added my 15mm spacers. I ended up getting gray lug bolts from radusa.com and powdercoated them black and added a clearcoat. However, the black is coming off on the edges even though I am very careful with nylon socket and torque wrench. Black engine paint did not work at all. My guess is that anodizing the lug bolts would be the best option but I do not know the cost.
Old Apr 9, 2009 | 09:58 AM
MadHatter's Avatar
MadHatter
These guys can help,
http://www.radusadirect.com/
Not sure about the black, metalic oxide though, they might offer them in black.
Good Luck
Old Apr 9, 2009 | 10:17 AM
matty125's Avatar
matty125
I agree, TXwerks for the win. super fast shipping, and you will have better wheel options w/ studs
Old Apr 9, 2009 | 11:14 AM
KrautHammer
Thanks guys, good info.
Radusa has no black and the studs from txwerks are a good way to go.
Do you loctite those in?
Old Apr 9, 2009 | 01:19 PM
btwdriver's Avatar
btwdriver
Yep you use blue loctite on the hub side threads. They actually go in with pretty minimal torque on the stud itself.
Old Apr 10, 2009 | 07:29 AM
KrautHammer
Thank you much.
Dec 23, 2015 10:36 AM
SosoMINI
Nov 22, 2015 03:17 PM
skippermini
Aug 12, 2015 10:05 PM
