Drivetrain MAF
Old Apr 7, 2009 | 12:45 PM
mtuning3's Avatar
mtuning3
MAF
does anybody know how to get the maf appart? i mean the sensor out of the housing
Old Apr 7, 2009 | 01:05 PM
ThumperMCS's Avatar
ThumperMCS
You just installed a GT28 on your mini and you don't know how to do that?
I'm sure you'll figure it out.
Old Apr 7, 2009 | 01:19 PM
mtuning3's Avatar
mtuning3
it looks like its glued together!
Old Apr 7, 2009 | 01:26 PM
Oxybluecoop's Avatar
Oxybluecoop
It is glued together.
Old Apr 7, 2009 | 01:33 PM
mtuning3's Avatar
mtuning3
need to cut it out to make a bigger maf
Old Apr 7, 2009 | 01:42 PM
a96bimmerm3's Avatar
a96bimmerm3
Why? It's tuned now?
Should be security torx, I don't see why the sensor couldn't come out. Could be wrong.
Old Apr 7, 2009 | 02:00 PM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
PUtting bigger pipe will yield issues big time. MAF calibrated for inside diameter of pipe. Hope you have a good tuning software.
Old Apr 7, 2009 | 02:24 PM
mtuning3's Avatar
mtuning3
the mass air flow is to small only 2.5 inch needs to be 2.75 at least for better flow ,testing some softwares right now its looking good so far
Old Apr 7, 2009 | 03:23 PM
a96bimmerm3
The software must be tuned for the MAF diameter like Hector says. Very important. You need to confirm this with your tuner, not just play with the size. It makes a large difference.
Old Apr 7, 2009 | 04:21 PM
mtuning3's Avatar
mtuning3
but of course!!!!!!im not born yesterday
Old Apr 8, 2009 | 02:10 AM
coopman7's Avatar
coopman7
From some of your posts it would seem you were born yesterday. You def photoshopped that turbo onto your car seen as you cant open an maf sensor
Old Apr 8, 2009 | 03:51 AM
mtuning3's Avatar
mtuning3
i was trying to get the sensor out nice and easy but it doesnt come its all glued together
Old Apr 8, 2009 | 11:24 AM
ThumperMCS's Avatar
ThumperMCS
+1
Old Apr 8, 2009 | 04:17 PM
BostonR56S's Avatar
BostonR56S
lol im interested in how old he is-
he cant form complete sentences... or rather, can only form run ons
Old Apr 8, 2009 | 05:46 PM
unclemeat's Avatar
unclemeat
put the maf after the turbo where the pipe diameter is smaller.
Old Apr 8, 2009 | 06:35 PM
richi0207's Avatar
richi0207
Good thing the box your turbo kit came in wasn't glued shut.
Old Apr 8, 2009 | 06:36 PM
scottab36's Avatar
scottab36
Why not just install the MAF from the 2009 JCW. I believe it's bigger.
Old Apr 8, 2009 | 10:43 PM
dtsoccer6's Avatar
dtsoccer6
any luck?
Old Apr 9, 2009 | 12:29 AM
Noegel's Avatar
Noegel
Exhaust Depot's response was the professional's way of calling bull****! It is odd that you have installed something nobody has done before but you can't take apart a simple sensor. I find it hard to believe that someone with supposedly significant technical knowledge believes that simply altering the size of a sensor will magically tie together your modified system.
Can't wait for the results...
Old Apr 9, 2009 | 04:36 AM
mtuning3's Avatar
mtuning3
the bigger maf will be calibrated in the tuning
Old Jul 11, 2009 | 07:52 PM
unit13's Avatar
unit13
I put mine in the cold air intake and let some of the air bypass it. runs sometimes a bit rough but lets in more air without recalibration. they do it on the WRX and other cars.
Old Nov 21, 2009 | 02:52 AM
DMBFan2's Avatar
DMBFan2
Where can I find my MAF sensor? I have an 03S w/98k on it and it gave me the SES light on my way home from work. The code was P0171 - running lean. I have read that cleaning the MAF sometimes helps, but where is it?
Old Nov 21, 2009 | 09:41 AM
Revolution Mini Works's Avatar
your car has 2 MAP sensors..... NO MAF
Old Nov 21, 2009 | 10:27 AM
DMBFan2's Avatar
DMBFan2
"your car has 2 MAP sensors..... NO MAF"
What would be the correct action to take since I received a P0171 code?
Thanks.
Old Nov 21, 2009 | 10:51 AM
DMBFan2's Avatar
DMBFan2
Where are these sensors? I am thinking that I paid for some bad gasoline (at least that's what the mechanic down the road propositioned) The autoparts manager at OReilly's said to put Lucas in the fuel and run it until it is almost empty then go somewhere else for gas.
Still, I need to know what I can do with a p0171 code and will it hurt if I continue driving it until replacement parts get to me? I took the day off thinking I would end up too far from home.
