R50/53 Control arm bolts
Old Apr 5, 2009 | 08:01 PM
4Boogie's Avatar
4Boogie
all throttle no bottle
Control arm bolts
Getting ready to install coils and rear control arms. The nuts on my rear control arms are welded on. I'm gonna order some other hardware from Morristown, the two bolts that hold the rear struts are rusty too. When replaceing control arms have any of you run into this problem? Can I just use a standard lock nut here? I'd like to replace everything with stainless, any suggestions???
Old Apr 5, 2009 | 08:20 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Not exactly sure what it is you want to do.
The nuts on the trailing arm that receive the bolts for the control arms are supposed to be welded to the trailing arm. You can still remove the bolts to install your aftermarket arms.
Where do you want to use a standard lock nut?
For the rust...spray some PB Blaster or WD-40 on the bolts/nuts.
Old Apr 5, 2009 | 08:24 PM
4Boogie's Avatar
4Boogie
OK the nut just stays I get it. I still want to use stainless hardware where ever possible
Old Apr 5, 2009 | 08:34 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Stainless hardware will be cool, but expensive. You will need to provide the thread size and pitch to the place where you are going to order the bolts. Morristown MINI won't have any stainless replacement hardware.
Old Apr 5, 2009 | 08:49 PM
Daverlee's Avatar
Daverlee
Just rememer that Stainless is actually softer (less hardness) than steel. Great for corroision but I have found that it is not a strong as grade 5 and surley not as strong as a grade 8 bolt.
Dave
Old Apr 5, 2009 | 10:13 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Dave
Yes, yes, good point, good point.
Just use anti-seize on the old bolts.
Old Apr 10, 2009 | 04:39 PM
TheAudiGuy's Avatar
TheAudiGuy
For suspension components, use Grade 10.9 or 10.6 (Can't remember exactly). Anything less and you're taking undue risk
Sep 3, 2015 02:06 PM
Sep 3, 2015 12:24 PM
Sep 3, 2015 10:29 AM
Suspension Products
Sep 3, 2015 09:41 AM
Ntety
Sep 2, 2015 08:39 PM
