Burning plastic smell
Old Mar 24, 2009 | 05:13 AM
SaltNPepa's Avatar
SaltNPepa
Just got me new S yesterday. It has a burning plastic smell that I did not remember from when we got our non s clubman. Is this normal with the S?
Old Mar 24, 2009 | 07:45 AM
Browser_23's Avatar
Browser_23
It is possible that all the cosmoline was not cleaned up from under the hood and if it drips on the turbo it will smell. See if you can pinpoint where the smell is coming from and look under your hood for signs of dripping. Look on the underside of your hood to see if you can spot anything.
Old Mar 24, 2009 | 12:03 PM
Crashton's Avatar
Crashton
I've had that type of smell on a few new cars. It dissipates after a while. Could very well be some of the cosmoline burning off.
Or it could be the hood scoop melting. Just kidding....
Old Mar 24, 2009 | 01:25 PM
mellowmcs's Avatar
mellowmcs
i had some of that on the rear of the car. i went umm sniffing and it seemed like it was the exhaust system, which is somewhat normal.
Old Mar 24, 2009 | 03:03 PM
edubledie's Avatar
edubledie
check your fluids make sure the caps are nice and snug cuz if not maybe they got loose and the fluids bubbled up and leaked out and are now burning ....( happened to me with break fluid , hyrdrolic engine mount fluid , and engine coolant lol )
Old Mar 24, 2009 | 03:28 PM
SaltNPepa's Avatar
SaltNPepa
Funny you say that. After spending so much time here looking at the S issues I am just waiting for my scoop to melt or the cold start chatter to pop up. At least my sunroof is quiet.
Old Mar 24, 2009 | 03:31 PM
Crashton's Avatar
Crashton
Lots of R56 MCS don't have any issues. Think happy thoughts, yours will be fine.
Old Mar 24, 2009 | 03:41 PM
mellowmcs's Avatar
mellowmcs
my car is at the dealer... getting a new hood scoop.
melted after 10months.
Old Mar 25, 2009 | 12:42 PM
SaltNPepa's Avatar
SaltNPepa
The smell seems to be comming from the tail pipe. I don't smell it much if at all when I open the hood but if I sniff the tail pipe area(with the car off) I smell it. I guess I will stop by the dealer on the way home from work on saturday and ask them.
Old Mar 25, 2009 | 02:01 PM
mellowmcs's Avatar
mellowmcs
it's normal. all my other cars did the same. it take a thousand miles or so for the exhaust to bake in and burn off whatever oil, etc that was used in manufacturing.
Old Mar 25, 2009 | 02:50 PM
MoxieMini's Avatar
MoxieMini
It's probably just new car smells. Mine had that smell thing going on. Completely went away almost immediately after break in.
Old Mar 26, 2009 | 04:34 PM
dvhone's Avatar
dvhone
Mine's the same, I'm not worried about...it's "New car smell", but on the outside!
Old Mar 26, 2009 | 04:51 PM
ahendy's Avatar
ahendy
Mine smelled like that one time when I first got 'er well..... near the speed limit.
Haven't smelled it since. I'm sure it's fine.
Old Mar 26, 2009 | 05:27 PM
SaltNPepa's Avatar
SaltNPepa
Thanks guys I like the idea of calling it the "out side new car smell" I just don't remember it with the Justa Clubman we have. I shall keep positive thougts in my head. my hood will not melt... my engine will not rattle...my hood will not melt...my engine will not rattle...
Old Mar 26, 2009 | 05:31 PM
ahendy's Avatar
ahendy
You probably didn't smell it in your clubman because the non-s engine doesn't get nearly as hot as the S engine does.
Regarding the hood scoop and engine rattle: My hood scoop melted after about 4k miles. Replaced it under warranty, and used a dremel to cut out the extra holes. Almost 10k miles later, and it's been fine.
I hear the engine rattle I guess. It's not bad, and goes away very shortly after setting off.. Don't worry about it, and enjoy your car!
Old Mar 26, 2009 | 06:04 PM
MoxieMini's Avatar
MoxieMini
You know, I actually caught the same smell coming from a brand new Honda Fit the other day, too.
And Ahendy is probably right. That N/A engine isn't going to get near as hot under the hood. Don't worry about it, anymore!
Old Mar 26, 2009 | 06:13 PM
SaltNPepa's Avatar
SaltNPepa
Not to hijack my own thread but I looked at my scoop and there are a few holes cut out. Do you think I should go and cut the rest out now or just wait an see. Im sure I could look around but it the issue a bad batch of scoops are just that the plastic is not up to the temps of the turbo?
Old Mar 26, 2009 | 07:19 PM
MoxieMini's Avatar
MoxieMini
It's a combination of high temps from the turbo and the hood scoop material. I would suppose you COULD take preventative measures by cutting holes to keep it cooler, but I wouldn't risk it as it's covered under warranty. There are much better options. Most dealers will let you swap the stock hood scoop for the JCW carbon fiber scoop +the difference if your scoop melts. Another solution (and it's probably the best solution out there) is to order a turbo heat shield from M7.
Sorry to hijack the question.
Old Apr 7, 2009 | 07:36 AM
Capt_bj's Avatar
Capt_bj
my 07 S is approaching two years old...I live in Florida so the car sees heat routinely...my scoop looks the same as it did on day one
Old Jun 22, 2009 | 11:58 AM
Parkerton's Avatar
Parkerton
I've had this for a couple days now...turns out there was a plastic bag stuck under my car that was producing the smell...it's not obvious, but that could be your source.
Old Sep 9, 2009 | 05:08 AM
asciilogic's Avatar
asciilogic
Yup...mine was a plastic bag as well. I couldn't believe it. I had to get super low to the ground to see it. Good thing it was yellow. I spoke with the Service Advisors at MINI of Manhattan and they said to take off the excess and let the rest (that is already burned to the underside) burn off.
Old Sep 14, 2009 | 02:27 PM
MINIxB's Avatar
MINIxB
My S has a weird kinda burning plastic smell too but I'm not worried about it...
Old Sep 15, 2009 | 05:27 AM
netma1000's Avatar
netma1000
The smell from mine was also coming from a melting plastic bag that was thrown under the car on the expressway. Once removed by the dealer, no more smell.
Old Sep 15, 2009 | 07:53 AM
Stig One's Avatar
Stig One
The burning plastic smell in my car came from my credit cards
RobbyD
Jan 29, 2019 01:22 PM
OutMotoring
Mar 3, 2017 06:29 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
