Drivetrain Evotech ECU Redline
Old Oct 7, 2003 | 04:01 AM
Gunthek's Avatar
Gunthek
I have read in this forum that the evotech and other ecu upgrades will raise the redline on the mcs. Is this redline raise visible from the tachometer? From what I understand, a mcs with pulley and evo ecu should have a redline of 7200 rpm (or ~7400 without the pulley). So does the software adjust the illuminated red bars of the mini tach to reflect this? Essentially I am trying to determine whether it's possible to verify an ecu upgrade simply by looking at the tach... thanks in advance.
Old Oct 7, 2003 | 07:24 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The redline is made up of non-thinking lights, unlike the E46 M3. What that means is, you will have to rev it to the new redline to check it.
The software from me for the pulley is set at 7200, whereas any other vendor selling the EVOTech has the redline set at 7500.
Hope that helps!
Randy
Old Oct 7, 2003 | 07:53 AM
05JCWS's Avatar
05JCWS
It would be cool if you could disable the lights. Maybe take the tach apart and remove the connections to two of the lights.
Old Oct 7, 2003 | 09:24 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
The Kombi module can be recoded to reflect a CVT (lower redline). But there may not be any plausible coding to reflect a higher redline. Good luck taking apart the tach, it's pretty messy in there.
bahman
Feb 14, 2016 10:29 AM
mni928
Nov 9, 2015 07:38 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
Sep 25, 2015 12:32 PM
