Suspension PSS9 rear rattle (just installed)
Old Mar 18, 2009 | 06:03 PM
Phantom's Avatar
Phantom
So I just replaced my old stock struts and promini springs with PSS9's OMFG! what a change, night and day, WAY BETTER NOW, except:
The rear rattles like crazy on little bumps, I think I missed puting a part in or something becuse damn it rattles sounds like they're loose or something to that extent I know for a fact I have everything tight, I checked 2x. Any ideas would be great.
Old Mar 18, 2009 | 08:04 PM
checkmate2006's Avatar
checkmate2006
Check your end links best place to start and also did you ditch the spacing collar from the oem struts.
Old Mar 18, 2009 | 08:22 PM
Phantom's Avatar
Phantom
endlinks are fine
yes, assuming thats the tube looking metal thing. thats about a 1.5" or so long.
Old Mar 18, 2009 | 08:36 PM
justintime's Avatar
justintime
I know you probably checked but is everything tight? there def shouldnt be a rattle with the pss9
Old Mar 18, 2009 | 11:17 PM
ninjlao's Avatar
ninjlao
Ninja Mini
If it's a clunking sound your springs may not be seated fully. Just something to check out...
Old Mar 19, 2009 | 01:51 AM
MINIdriver85's Avatar
MINIdriver85
How do you determine if the springs are fully seated or not?
Old Mar 19, 2009 | 04:18 AM
Phantom's Avatar
Phantom
i think Im going to take it all apart in the rear and take a CLOSE look at it all when I get off work today. untill then please keep on posting with ideas.
sidenote I only lowerd it on the pss9 bodies about a inch all around, AND I still have the helpers on.
Old Mar 19, 2009 | 07:49 AM
checkmate2006
Originally Posted by Phantom
endlinks are fine
yeah take that metal sleeve out. I had the same clunking sound with my megans in the rear I have had the sleeve out since I have figured it out and haven't had a single problem with the rear since. When the rear's are on do they have alot of range of circular motion/free swing? If so that means they aren't tighten down all the way to the point that the bushing is sandwiched between the topnut and washer, oem top hat, and then the pss9 top hat. Then when you mount the top hat back to the body mount it should be a shorter range of circular motion/free swing but at the same time very solid feeling and well assembled.
Old Mar 19, 2009 | 08:03 AM
UKSUV's Avatar
UKSUV
I cant remember how my PSS9's look. They are crammed up in the wheel well....I cant see them....
Old Mar 19, 2009 | 08:42 AM
checkmate2006
My megans are the same way.
Old Mar 19, 2009 | 12:10 PM
UKSUV's Avatar
UKSUV
Beotch please....you know that 4x4 cant relate to mine...
Old Mar 19, 2009 | 01:44 PM
checkmate2006
Are you cereal I am tucking a little tire on 17's but I guess the hamster-mobile has to be tuckin rim also to be crammed up.
Old Mar 19, 2009 | 01:53 PM
UKSUV's Avatar
UKSUV
DOOOOOOD.....LOOK AT THAT WHEEL GAP!!!!!!
Old Mar 19, 2009 | 02:22 PM
checkmate2006
What are you talking about wheel gap DOOOOOOD
Old Mar 19, 2009 | 03:29 PM
Phantom's Avatar
Phantom
DO I USE ANY FOAM BUMPERS AT ALL WITH THE PSS9s? I found out that the hat was sliding about as it didnt seat.
Old Mar 19, 2009 | 04:34 PM
Wake|MCS's Avatar
Wake|MCS
Wish I could help you but I don't remember how I put mine on. Pretty sure you gotta use the factory top-hat as is (minus a spacer or something that's replaced) but I'm probably just confusing you.
Hey check, I still see some gap up front.
J, how's your car treating you?
checkmate2006
Use everything except for that metal sleeve we have been talking about.
Old Mar 19, 2009 | 04:37 PM
Wake|MCS's Avatar
Wake|MCS
Yeah, the foam from the factory top-hat has to be re-used
Old Mar 19, 2009 | 04:55 PM
UKSUV's Avatar
UKSUV
Is he talking about bumpstops? I reused the metal plate and rubber piece I think until I went to camber plates...
Old Mar 19, 2009 | 05:01 PM
UKSUV's Avatar
UKSUV
Mini is good but the BMW is EVEN BETTER...
Not to threadjack the OP but I bought 19" CSL's (E46 offests up front....E92 offsets in the rear stretching 215's...Should be 285's! ), K-Sport coilovers, custom rear bumper lowered 2", M3 mirrors for FREE, Vorsteiner GTS3 lip and M3 bumper. Gonna shave the reflectors and fog light holes. Also, lower the skirts about an inch. Before I paint I am going to get a CSL trunk and ACS roof spoiler. Then I will black out the lights and trim. One thing I might do is powdercoat the wheels black....vinyl the center section of the lip and my roof... And sorry to the OP.....lol
Old Mar 19, 2009 | 05:11 PM
UKSUV's Avatar
UKSUV
Here you go Alex....you need to fix these by the time I see you next..
Old Mar 20, 2009 | 03:45 AM
Phantom's Avatar
Phantom
I fixed it, Im dumb, dosent help that I was in a rush fighting sundown. Now the rear is a tad higher than I wanted but I rather have that extra play in the strut than lower it. Now I have to raise the front 1/2" Im only assumg they were made to be able to adjust with weight on them, Just seems to me the nuts are made of a soft metal.
Old Mar 20, 2009 | 04:56 AM
Phantom's Avatar
Phantom
There still is a very very slight rattle, but nothing like it was, Im happy now, just have to raise the front and get it aligned, I hope the place knows how to work with kmacs.
Old Mar 20, 2009 | 07:10 AM
checkmate2006
The only thing that would change would be the BFE becaue I would be PHX MANNN.
Old Mar 20, 2009 | 04:17 PM
UKSUV's Avatar
UKSUV
Well then your running my same setup. I have PSS9's with KMAC's. I think we are the only ones with this setup... On my rears Im dropped on rim. The fronts cant go lower but Im about 3/4" from tire. But If I drop it any lower I will be on pavement. The KMAC's are a pretty decent plate. I have had no problems with them. The only thing is with the fronts all the way down AND the plates installed....my springs bind... But whatever....my Mini is a play car...
