Overfilled 1/2 quart engine oil will cause problem?
Old Mar 10, 2009 | 08:58 AM
imbz's Avatar
imbz
I put 5 qt of engine oil in my mini but it suppose to put only 4.5 qt.
Do i need to take it out? Or it would be okay only 1/2 qt.
Old Mar 10, 2009 | 09:15 AM
jaridp's Avatar
jaridp
If it was my car I would take it out. Have you checked the oil level on the dipstick to see how things look?
Old Mar 10, 2009 | 09:25 AM
mini_racer's Avatar
mini_racer
If going for some track or dyno time, many have suggested to add the extra half quart. That tells me it can't be a bad thing to have a little bit over.
Old Mar 10, 2009 | 09:54 AM
djam43's Avatar
djam43
Suck it out.!!!
Old Mar 10, 2009 | 10:37 AM
imbz's Avatar
imbz
Originally Posted by djam43
Suck it out.!!!
How to suck it out???
Old Mar 10, 2009 | 01:17 PM
GregO's Avatar
GregO
oil
For mine, I bought 1/4" tygon tubing from a bigbox hardware store and a siphon bulb from and autostore (the tube that came with the bulb was too large diameter to thread down the dipstick tube). It worked, but after all was said and done, it was not worth it. If it bothers you, do it. Realistically, 1/2 a quart is not going to hurt anything.
Greg
Old Mar 10, 2009 | 01:45 PM
quikmni's Avatar
quikmni
As stated, check the dip stick to see overfilled it really is. Might not be the far above full. 1/2 quart should not be a problem. In my opinion, not worth sucking oil out. If it really bothers you just drain a little out from the drain plug (will be a bit messy but if it helps you sleep better, well worth the mess).
Old Mar 10, 2009 | 01:58 PM
zminitech's Avatar
zminitech
You'll be fine, as long as it's only a 1/2 quart.
Old Mar 11, 2009 | 07:01 AM
imbz's Avatar
imbz
I was check dipstick, the oil level is above the top mark about 1/2 inch. Hmm.. It's the world hardest dipstick to read. It need bright day light with paper towel.
Since it has no any bad sign. I think it should be Okay too to leave it 5 qt in oil pan. It's properly common mistake for many people (like me.)
Old Mar 11, 2009 | 10:16 AM
sequence's Avatar
sequence
on any other car y'd risk blowing a crankcase seal by overfilling the oil by that much. I would try to drain some out (messy yeah), recheck, and refill.
and check MossMini, MINIMania, etc for a/m R56 dipsticks that are a LOT easier to read. I have one on mine, and it's soooo much less hassle.
Old Mar 11, 2009 | 11:00 AM
cacattlerancher's Avatar
cacattlerancher
In a jetta 1/2 qt kills the milage
Old Mar 12, 2009 | 08:14 PM
Benibiker's Avatar
Benibiker
Why risk it, take it out. What do you think the dealer will say when something happens to your engine and you want warranty work?
Old Mar 12, 2009 | 09:01 PM
imbz's Avatar
imbz
Thanks for all guys, I decided to suck it out 1/2 qt. It was cheap insurance for engine. Now Oil level just in top place of dipstick.
Kimolaoha
Jul 5, 2023 01:04 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
minipopkart
Aug 13, 2015 05:22 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
