Suspension R56 lowered - more positive rear camber
Old Mar 6, 2009 | 04:45 PM
kartking's Avatar
kartking
I just had my 09 JCW coupe lowered
I want to get rid of some of the negative rear camber.
Does anyone know how much camber can I correct without changing
lower control arms?
Right now the rear camber is negative 2 degrees
Old Mar 6, 2009 | 04:48 PM
lhoboy's Avatar
lhoboy
lower control arms?
Leave it there. It will handle better.
Old Mar 6, 2009 | 04:51 PM
onefish2's Avatar
onefish2
I agree just leave it alone. I just had the JCW suspension installed on my 09 factory JCW. This introduced and additional 1 degree of negative camber. It looks a bit odd but does improve the handling.
Old Mar 6, 2009 | 05:08 PM
SK8BRD's Avatar
SK8BRD
Factory eccentric has 4 degrees of adjustment. With a 3/4 rear drop my adjustment range was +1 to -3 in the back. Stock was plus or minus 2 degrees.
Old Mar 7, 2009 | 03:52 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
How much camber do you have up front? You could just leave alone. Get camber plates and run 2 degrees up front as well.
Old Mar 7, 2009 | 04:17 PM
a96bimmerm3's Avatar
a96bimmerm3
Old Mar 8, 2009 | 06:07 AM
maacodale's Avatar
maacodale
We just put H&R springs on the sons R56. It dropped it about 1.5 inches and added some additional camber. We had Ireland engineering fixed camber plates which gave us about -1.3 camber. The H&R's bumper that to -1.8 front and -1.3 rear. HE does a lot of highway driving back and forth to school in Charlotte so we'll keep an eye on that, but that'll offset things in autocrosses. Can't wait to do something with the Clubman!
Old Mar 8, 2009 | 07:22 AM
mzangari's Avatar
mzangari
I just had mine lowered, with Eibach Pro-Kit Sport Springs....Hotchkis rear camber kit....the increased negative camber has certainly improved handling - quite considerably! I am very happy with this setup.
Old Mar 8, 2009 | 07:42 AM
k-huevo's Avatar
k-huevo
lower control arms?...
The amount of adjustment remaining depends on where the bolt is positioned currently. There is .5 degrees of effective adjustment available from a 180 turn of the bolt. If the arm is already shortened, no adjustment will be available.
Originally Posted by SK8BRD
Factory eccentric has 4 degrees of adjustment...
Nope
W0TM8
Dec 19, 2019 07:50 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
