Valve cover gasket HELP
Old Feb 26, 2009 | 05:54 AM
EricMOTOR's Avatar
EricMOTOR
I am having a leak from my valve cover... I bought the new gasket from the dealership but before installing I need to know what to torque the vale cover bolts to. Any knows?
Old Feb 26, 2009 | 06:09 AM
xsmini's Avatar
xsmini
9 ft/lbs
Nik
Old Feb 26, 2009 | 06:15 AM
EricMOTOR's Avatar
EricMOTOR
Thanks man! I really appreciate it!
Is there a how to or DIY for this? If not I may just have to get my note pad out and get the camera ready when replacing it.
Old Feb 26, 2009 | 06:42 AM
k_h_d's Avatar
k_h_d
Yes, please make a DIY if you do this . I have to do mine sometime
Old Feb 26, 2009 | 07:21 PM
xsmini's Avatar
xsmini
Old Feb 27, 2009 | 01:57 PM
Alan's Avatar
Alan
Thanks - very informative. Didn't know about spark plug tube seals.
Alan
p.s. Also probably a copyright violation...
Old Feb 27, 2009 | 02:50 PM
xsmini's Avatar
xsmini
LOL - likely -
Nik
Old Mar 1, 2009 | 04:04 PM
1FSTMINI's Avatar
1FSTMINI
Removing And Installing, Sealing Cylinder Head Cover (COOPER S)
Remove intercooler.
Remove bolts (1) securing left hand bracket and remove bracket (2).
Mounting screws for mounting (Left) of intercooler to intake manifold
M6 9 Nm
Remove bolts (1) securing right hand bracket and remove bracket (2).
Mounting screws for mounting (Right) of intercooler to intake manifold
M6 9 Nm
Disconnect hose (1).
Disconnect PCV valve (2).
Disconnect connector to coil pack (3).
Remove plug caps (twist and pull) (4).
Remove harness clips from inspection cover bolts.
Remove coil pack.
Remove 12 cylinder head cover bolts.
Remove cylinder head cover.
Install hint:
Replace cylinder head cover gasket if necessary.
Clean mating faces with a suitable material.
Note: Cylinder head cover fixing screws are separate from the cylinder head cover.
Replace retaining screws and insulators if damaged.
Install hint:
Install cylinder head cover and tighten screws to sequence.
Cylinder head cover to cylinder head 12 nm
The Cooper engine is the same less the IC of coarse
Old Mar 2, 2009 | 01:30 PM
Alan's Avatar
Alan
I don't see any pictures.
Alan
Old Mar 3, 2009 | 08:53 AM
1FSTMINI's Avatar
1FSTMINI
figures...they always work for a min then disappear. ill put em back up later on.
Old Mar 22, 2009 | 12:46 AM
mmaluso's Avatar
mmaluso
I just attempted to change out my valve cover gasket and it just wasn't working out. I got the bentley manual that gives pretty much the same description as above but for the life of me I could not get the valve cover off. It just would not clear that plastic cover to the fuel rail. The two tabs that the plastic engine cover click into to be specific. I have an automatic.... does that make a difference? Any tips? I really don't want to take it to the dealer. do i have to take the fuel rail off?
Old Mar 22, 2009 | 03:03 AM
Mini-Morgan's Avatar
Mini-Morgan
Is that a Cooper??
I have had mine off about 6-8 times now and still havent replaced the seal and doesnt leak one bit. Must be lucky I guess but the process is exactly as about but being careful not to damage the plug tube seals.
Old Mar 22, 2009 | 09:34 AM
mmaluso's Avatar
mmaluso
It's a cooper and the gasket is leaking. I am planning on replacing the plug tube seals also but I just can't get the cover off. There has to be something I am missing here. Two of the front bolts are partially covered by this plastic cover for the fuel rail. I have to jam a socket in there to unscrew them but that is the area that won't clear.
Old Apr 20, 2009 | 12:14 PM
CARdiac's Avatar
CARdiac
I would love to have the pix fixed.... or can you email the whole thing to me?
Old Aug 8, 2009 | 04:07 PM
jollyroger927's Avatar
jollyroger927
MSD just did the same to me. Did you reinstall the MSD on the new cover?
Old Feb 23, 2010 | 09:40 AM
knotcher's Avatar
knotcher
does anyone know of a better write up for a valve cover gasket change? it's not a difficult job, and my main quesiton is about the tube seals...do they really need to be changed? and if so, what's the part number...i can't find them anywhere???
Old Feb 23, 2010 | 09:47 AM
Mini-Morgan
off and on many times and never changed any of the seals including the valve cover. I would recommend that you do but the tube seals I wouldnt say are important as they are only to stop oil splashing out.
Old Apr 9, 2010 | 07:01 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
At 91K miles pulled #1 spark plug and noticed dripping oil from the electrode....then checked the bottom of cyl tube and saw oil. Same but not as bad for #2 cyl.
Tube seals were shot. Replaced along with a new valve cover gasket.....
FYI - Like most of the MINI's nuts and bolts the valve cover bolts often are pretty corroded and can be difficult to remove.... I would order up some from MINI to have on hand before tackeling this job. There are several different types of bolts which hold it down.
But for the sake of being thorough, I ordered all 12.
Old Apr 20, 2010 | 03:18 PM
tonester's Avatar
tonester
anyone have the pics from the DIY above? in addition, do you guys use any RTV sealant to attach the gasket to the valve cover prior to re-installation?
Old Apr 17, 2011 | 01:00 PM
JustinGTP's Avatar
JustinGTP
Any update on his thread? This is something I might want to do shortly. I would like the pics back
Old Apr 26, 2011 | 03:09 PM
rickyr53's Avatar
rickyr53
Bump! im about to do this now but wanted to see pictures first.
Old May 27, 2011 | 07:06 PM
BillyCuth's Avatar
BillyCuth
no choice but to at least pull this cover off for me... The nuts holding mine on in the front are completely rusted away. I figure I will just take it all off and clean it up while I am in there... Pix def. appreciated guys!
I was doing my detroit tuned BPV when I noticed the nuts were all but missing (just some dust left)...
Old Jan 30, 2012 | 05:42 AM
ART ED's Avatar
ART ED
Leaking valve cover gasket
I have 35K miles on my 08 clubmanS and it has a leaking valve cover gasket. Now that I am out of warranty how much should it cost to get fixed? I extended my warranty last year and hope it will be covered under that extension from Mini. The warranty is with mini.
schwac2
Sep 11, 2015 11:13 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
azntaiji
Aug 13, 2015 03:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
