R50/53 On board computer
Old Feb 25, 2009 | 12:26 AM
moseichuk007's Avatar
moseichuk007
On board computer
How do you switch the display on the tach if you have an OBC? I don't know if my mini came with it, im pretty sure it didnt. But where would the button be located or how is the display usually cycled through? like from mpg to how many miles are left on the tank to temp.
also if you dont have the onboard computer how do you make it display the digital speedometer on the tach instead of the temp? and vice versa.
Thanks in advance.
Old Feb 25, 2009 | 04:20 AM
03BRG's Avatar
03BRG
The trip computer switch is on the blinker stock with a pic of a computer on it.
Old Feb 26, 2009 | 06:27 AM
ClubmanS's Avatar
ClubmanS
If you have a '04 and newer R53 MCS:
Beginning with MY2004, MINI included the digital tach speed LED readout regardless of whether you ordered the optional OBC trip computer or not.
If you don't have OBC, the only read outs available to you (By cycling the turn signal/lights stalk button) will be exterior ambient temperature "Temp" and speed "Speed".
If you do have OBC in your car, you will be able to cycle through the following prompts:
Ambient temperature
Speed
Miles to empty
Average fuel consumption
Instant fuel consumption
Average vehicle speed
Again, these prompts will be visible by cycling the turn signal stalk button.
If you have a 2002 or 2003 MINI (MC or MCS) without OBC, the only prompt you will get in the tach is for exterior ambient temperature and no stalk button.
If your '02-'03 MINI has OBC, you will have all of the prompts listed above, except, actual vehicle speed.
Hope this helps.
PS: Read the owner's manual that came with your car. If you don't have it, you can either download the correct manual for your model year from the MINI Owner's Lounge or Motoringfile.com for free. The manuals are available in PDF Acrobat reader format.
Old Feb 26, 2009 | 12:58 PM
moseichuk007
thanks for the reply. turns out i dont have an OBC. so the only display i can have is the ambient temperature.. sort of sucks.. but better than nothing.
Old Feb 26, 2009 | 01:44 PM
ClubmanS's Avatar
ClubmanS
I believe the OBC can be retrofitted but I am not sure about the costs and implications in doing so.
Old Feb 26, 2009 | 01:46 PM
moseichuk007
yeah i've read up on adding it to the car and it "seems" possible, although i dont know if its something that would be worth doing. But its something that i still think about.
Old Feb 26, 2009 | 04:17 PM
ttttaylor's Avatar
ttttaylor
i have an '03 MC and it only shows temp, miles, avg. fuel consumption, and avg. speed...
i REALLY wish it had instant fuel consumption and actual speed.
Old Feb 26, 2009 | 06:36 PM
ClubmanS's Avatar
ClubmanS
Yep, you have the older version of the OBC
Old Feb 26, 2009 | 06:50 PM
ttttaylor's Avatar
ttttaylor
what do i need to do to upgrade?
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
madmix
Oct 5, 2015 09:58 AM
dutchhome
Sep 30, 2015 07:17 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
