R50/53 Strut tower mushrooming repair
Old Feb 20, 2009 | 09:39 AM
FastGreenMINI's Avatar
FastGreenMINI
Has anyone gotten the mushrooming banged out at a body shop and how much did it cost?
Old Feb 20, 2009 | 09:43 AM
healey67's Avatar
healey67
Well..... How bad is it? Are you replacing the strut tower mounts?? (you should be if your fixing the tower itself).
Old Feb 20, 2009 | 10:49 AM
pmustang's Avatar
pmustang
it is so simple I did in my driveway, Jack up the side of the car you are going to work on, undo the three bolts that attach the strut and let it settle down so the bolts drop out of the holes, take a hunk of 2x4 and lie it on the top of the strut tower, then bash the living daylights out of it with a 5lb sledge. It was super easy and all joking aside if you take care as I did you have no paint damage at all. Mine are now flat and have Craven STDs on them. The Craven plates allowed me to see how they should be when done, once they fitted nice and flat I bolted them up.
Old Feb 20, 2009 | 11:13 AM
bobbyb714's Avatar
bobbyb714
I had it bad on one side i replaced the mounts but instead of banging "the living daylights out of it "you may want to have it pulled back down into place.Then i got the m7 stb and plates and oh also got rid of the run flats
they may add to the situation as well.I have several thousand miles of the car tire wear is fine .
Old Feb 20, 2009 | 11:16 AM
gen3usa's Avatar
gen3usa
what is the biggest culprit to this becoming an issue? i see alot of talk about it but would like to know what to look for or avoid?
Old Feb 20, 2009 | 11:40 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
My mushroomed strut top was fixed (wood and mallet method) when camber plates were added.
Avoid any rim larger than 16", avoid runflat tires, potholes, speedbumps, railroad crossings, expansion joints, etc.
Old Feb 20, 2009 | 11:51 AM
blkkouki's Avatar
blkkouki
pretty much anything but a track lol
Old Feb 20, 2009 | 12:09 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Well, with a light rim, a tire that has some give, and any kind of strut top plate, camber plates, and polyurethane control arm bushings, you can pretty much run over anything and come out of it.
Old Feb 20, 2009 | 12:30 PM
ClubmanS's Avatar
ClubmanS
Some of you must live in places with really wicked roads. I also think the combination of stiff suspension + big rims and low profile tires do not help the cause.
Old Feb 20, 2009 | 12:44 PM
Silverbullit's Avatar
Silverbullit
Mushrooming is a problem on the 1st Gen. cars. It's too bad that BMW won't own up to the fact. I took care of mine with the 2x4 and hammer method. It now has M7 plates and strut rod and non R/Fs.
Old Feb 20, 2009 | 02:34 PM
gen3usa's Avatar
gen3usa
mine is lowered and has 17" team wheels, our roads are not that bad, i been looking at those strut bars for under the hood, with those brackets that wrap around, would that be a good investment? excuse my lack of knowledge, new to the mini scene, just picked up my 04 with 26k on it, also found out the prior owner already did some mods. CAI, and suspension mods, not sure what mods the suspension went threw but it has green springs in the back with white #'s on it, fronts i cant tell. please be patient with me as i become addicted to the MCS!
Old Feb 20, 2009 | 08:07 PM
Ancient Mariner's Avatar
Ancient Mariner
Start here:
https://www.northamericanmotoring.co...ollection.html
Read all 17 pages; 400+ posts. Answers to all of your questions.
'Search' is your friend...
(Hi Nab!)
Old Feb 21, 2009 | 01:46 AM
pmustang's Avatar
pmustang
What amazed me is that I was fully aware of the STM problem and thus when I bought my car I looked at a bunch in the lot to ensure mine was like "all the others" and thus (I thought not suffering from STM) Well that was until I bought the cravens and saw when trying to fit them that the slight upward bulge that all the cars had on the lot was not stock!! In the UK where I live we travel tons of country back roads and they are horrid, thus I probably have more chance of having this problem than most folks. After our recent heavy snow and frost the amount of pot holes is incredible.
Peter
Old Feb 21, 2009 | 08:22 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Originally Posted by Ancient Mariner
Start here:
(Hi Nab!)
That really is the best place for mushrooming strut information.
(Hi A.Mariner! I should work on more drawings...)
Old Feb 21, 2009 | 06:31 PM
Ancient Mariner
Yes, you should. You'll never get famous if you hide your
light under a basket.
Old Feb 23, 2009 | 03:17 AM
bobbyb714's Avatar
bobbyb714
The best place to get mushrooms is a dark cool place.Yet for a Mini the streets of NYC is a good place to get some .In fact this time of year going into the spring is like mushroom season with new pot holes sprouting up where all you have to do in drop in and get them .Of course i would think if you hit curbs or like driving 60 over speedbumps you may pick a few as well .
Old Feb 25, 2011 | 08:24 AM
jfahys's Avatar
jfahys
Mushrooming Fix Steps
I am going to attempt the 2x4 method to fix mushrooming. What steps should I take? And once completed what parts should I replace above and below? Is this expensive?
Old Feb 25, 2011 | 08:34 AM
erickvonzipper's Avatar
erickvonzipper
Basically, just whack them so they flatten down until you can place an M7 or some such plate on them and get the nuts a couple of turns down on the bolt before you encounter resistance. Then, when you tighten the nuts down with a wrench, the plate will basically finish the job of flattening for you.
Old Feb 25, 2011 | 09:30 AM
Walt's Avatar
Walt
There is also a 2-hour closed book exam at the end.
Old Mar 3, 2011 | 12:53 AM
kimban's Avatar
kimban
I went to unbolt the three tower nuts, place the m7 plate, and mines is about 1/4 inch off.. I take it that I will have to remove the strut before straighten it back in place?? Correct me if I am wrong, I am new to this, The plate should be flush all around correct? Should be fun. Thanks in advance for the help.
minijoopers
Sep 9, 2015 03:36 PM
M7Speed
Sep 4, 2015 10:47 AM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
