Yay another problem! smoke from my AC/heating vents!
Old Feb 18, 2009 | 08:31 AM
Type R 564's Avatar
Type R 564
So the other day i was driving home and there was smoke coming out of all my vents inside the car. it also smells like antifreeze so i have to drive with my windows down at all time!!! it also keeps fogging up all my window so at some points i cant even see out so i have to pull over. its either smoke or steam, but its smells like antifreeze. and its been doing this for about 3 days now. anyone know what is wrong?
thanks
-Fred
Old Feb 18, 2009 | 08:51 AM
Dr Obnxs's Avatar
Dr Obnxs
I'd guess
that your overflow tank is cracked and/or the cap is failing, and it's getting sucked in the vent system. But you HAVE to check levels. Three days is a long time, and if you loose too much coolant, you'll have a lot more to replace than just an overflow tank and some coolant. If you don't work on your car, have the cooling system pressure tested at a shop.
Matt
Old Feb 18, 2009 | 09:17 AM
03BRG's Avatar
03BRG
heater core is bad
Old Feb 18, 2009 | 09:21 AM
ricbow's Avatar
ricbow
+1
Old Feb 18, 2009 | 09:56 AM
thecigarman's Avatar
thecigarman
Simply driving with the windows down will not prevent yoy from getting poisoned by the coolant fume, it will just slow it down.
http://en.allexperts.com/q/Toxicolog...eeze-Fumes.htm
Get your heater and a/c checked ASAP.
Old Feb 18, 2009 | 11:27 AM
Dr Obnxs's Avatar
Dr Obnxs
Cood call
on the heater core....
Matt
Old Feb 18, 2009 | 01:30 PM
Type R 564's Avatar
Type R 564
thanks for the help, i guess im just gona take my car to the dealer asap!
ill keep you guys updated
cub4bearindiana
Jun 30, 2016 06:11 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
Gil-galad
Eastern Iowa MINIs
17
Sep 12, 2015 07:13 AM
robbiedowns22
Aug 25, 2015 12:20 PM
Shane Wendel
Aug 21, 2015 01:04 PM
