R50/53 Speedometer jitter?
Old Feb 17, 2009 | 10:13 PM
qbunt's Avatar
qbunt
Speedometer jitter?
I've got an '03 MCS, and in the cold (or wet it seems), when I start 'er up, the speedometer needle jitters between the 0 mark and the needle stop very fast for about a second or two. When the car is running, it operates normally. When I shut the car off after I've been driving for a bit, and restart it, it does not happen again, until I leave it for a while.
Any ideas on what this might be? I bought this car about 6 months ago, and once in a while it takes a couple cranks to get it started, but other than that it's been reliable. I initially thought it was the battery, but I've never had that much trouble trouble starting it up. Thoughts?
Old Feb 18, 2009 | 05:59 AM
03BRG's Avatar
03BRG
Lots of info on this. The battery is on its way out the voltage is dropping and the speedo is doing a reset. Go to someone that can load test the battery. No known problems from it doing a reset but you will find that over a few months it will take less and less cold temps to get it to reset as the battery dies.
Old Feb 18, 2009 | 01:02 PM
qbunt's Avatar
qbunt
That's what I was afraid of. Yeah it does seem to be happening much more frequently now. I'll have the battery tested. Thanks a ton for the quick response.
Old Feb 21, 2009 | 03:29 PM
qbunt's Avatar
qbunt
Just put an Optima RedTop 34R in. Turns out I was still on the original battery, can't believe it hung on for this long. Thanks again for the help.
triple5soul
Nov 19, 2019 07:46 AM
stoneunhenged
R58 :: Coupé Talk (2012+)
Sep 24, 2015 02:19 PM
jeremy_reyes94
Aug 26, 2015 10:10 AM
maniacalmorgan
Aug 21, 2015 03:03 AM
maniacalmorgan
Aug 20, 2015 01:08 PM
