R50/53 A/C controls dead?
A/C controls dead?
ive checked connections and everything is good there, only other thing i can think of that i havent checked yet is the fuses. ill check that later. basically im just driving yesterday and i went to turn the air on and i notice they didnt turn on, no lights, nothing
was working 5 minutes prior to this
btw, i had the bass up pretty loud
i am when i get home from work. off the top of your head, do you know which number fuse it is in the kick panel? i have the diagram somewhere at the house.
Doh, guess I was too busy laughing my *** off at the prospect of having enough bass to actually break the electronics in your car. According to Bentley the relevant fuses are:
F5: Instruments
F9: Instruments
F14: General Module (BC1); Interior lights
F21: Instruments
F29: Air-conditioning control panel
F30: Instruments
F40: Instruments; front console switch panel; steering angle sensor.
So start with that.
F5: Instruments
F9: Instruments
F21: Instruments
F30: Instruments
So start with that.
I seem to recall you had talked about relocating the a/c controls so you could put an LCD screen in it's place. Did you? Any relocated, extended, cut, or soldered wires could have upset the balance of the circuit and caused the fuse to blow. Just an idea.
i did extend wires, that could be the problem, but its been about 6 months and this is the first time a fuse blew. might have had the air on + bass and the voltage may have dropped a little too low
oh well, all is good, replaced the blown 5A fuse with a new 40A
jk, hahahahhaha
jk, hahahahhaha
popped another fuse today and a/c controls went out. replaced it and its fine. it only seems to happen if i have the a/c on full blast, and the bass on full blast as well. i dont think itll happen when i get some more batteries to help with the voltage.
patsum
26
May 29, 2021 06:29 PM
doug5g
Sep 2, 2015 04:53 PM
