Thanks guys! Mine is a fist gen mini by the way not a 2nd. I used 4" orange ones in the driverside and passenger side foot wells. 2" under each passenger seat for the back feet. And 1" in each junk compartment that is under the back speakers.
Looks good I might just try the rear pockets myself
Do they brighten/dim with the dome light? If so, where did you tap in?
You could tap into any light in there that dims the way you want. I'd recommend the light in the boot depending on if you take off the rear panel or not. That way the wire would already be hidden and super easy to feed there.
I didnt wire them up to the lights inside to dim they are wired in with two switches one controls the front zone the front floor wells. The second switch controls the ones under the front seats and the rear pockets. I wanted them to stay on at night for driving sometimes or if im showing the car off and what not.
