R50/53 Headlamp Replacement
Old Feb 3, 2009 | 03:16 PM
Trilobite's Avatar
Trilobite
My passenger-side headlamp burned out on my 2002 Cooper. I purchased a bulb from the local autoparts store, and went to replace it, but I can't figure out how to remove the bulb from the holder - it's somewhat awkwardly placed. Can anybody give me any tips?
Old Feb 3, 2009 | 03:42 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I take it you have the non-xenon type headlights. That being the case, I assume changing them is like changing the high beam on the xenon headlights. There is a circular rubber hatch that pops off giving access to the bulb. Unplug the bulb, then move the shiny containment wire to the side allowing the bulb to slide out.
Old Feb 3, 2009 | 03:47 PM
Trilobite's Avatar
Trilobite
Yep, I was able to find the rubber hatch, and was working to get the wires undone, but there is the black attachment that holds the power wires to the bulb - It appears as though I have to get that off first. It might be the way that it was put on in the first place. I'll give it another go tonight and see if I can get that. Essentially, I'm having trouble getting that shiny wire off...
Old Feb 3, 2009 | 03:52 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I forget how it goes off. It might have a clasp design on one end of it, or it might just slide off like an old jar lid wire.
Old Feb 3, 2009 | 03:55 PM
Trilobite's Avatar
Trilobite
I think there's a clasp, I was able to get part of it off.
Thanks!
Old Feb 3, 2009 | 04:34 PM
Trilobite's Avatar
Trilobite
Okay, I was able to change the bulb!
BUT:
It didn't go on, at least on low beams. The bulb works the same as it did before, but it seems like there might be a problem with the low setting. Any further tips?
Old Feb 3, 2009 | 05:11 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'm not sure what the case is. When I replaced my high beam/daytime running lights (same bulb) they were plug and play, so to speak. My xenons are in great shape and should last eons.
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
JPMontes3
Aug 23, 2015 01:26 AM
Powershift
Aug 16, 2015 05:14 PM
