Suspension R56 Wheel Alignment
Old Jan 30, 2009 | 06:28 PM
scottab36's Avatar
scottab36
R56 Wheel Alignment
What is the difference from the for wheel alignment the the MINI dealer does (approx. $140.00) compared to the alignment you get done at the local wheel and tire shop (approx. $75.00)?
Oxybluecoop's Avatar
Oxybluecoop
Nothing but $$.
Old Jan 30, 2009 | 07:07 PM
oldchicago's Avatar
oldchicago
Look for a shop that can print out a inspection sheet that shows before and after specs. Be careful of chain shops the may only "Set the toe and let it go"
Old Jan 31, 2009 | 06:08 PM
Noegel's Avatar
Noegel
Let's say I modify my suspension with a rear bar, coilovers, and control arms... where would I get my alignment done then?
Old Feb 1, 2009 | 05:37 AM
oldchicago's Avatar
oldchicago
Same type of alignment facility, The computerized systems that provide a printout of before and after specs compared to factory specs. Let the shop know of your changes to the suspension so they can adjust properly vs. thinking something is bent. - Mark
Old Feb 1, 2009 | 02:26 PM
Noegel's Avatar
Noegel
Thanks! Can't wait for the suspension modifications to come in!
Old Feb 7, 2009 | 02:17 PM
n1tr0's Avatar
n1tr0
Check your local Nissan dealers, any of them selling the new GTR will have an uber expensive laser alignment rack that they'll be desperate to make up the cost on. It's way more accurate (and repeatable) then the older style racks and will have the R56 including the JCW & sport suspension settings.
You can usually get the alignment done for around $90, just ask if they have any alignment specials.
sevin
May 2, 2026 06:11 AM
maestro39
Oct 27, 2015 02:38 PM
trw92a
Aug 26, 2015 01:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
