R50/53 Climate control dead... intermittently
Old Jan 26, 2009 | 08:29 AM
karrera4's Avatar
karrera4
I have an 03 MCS w/ 40K easy miles (orig. owner). It does not get driven much anymore and is basically awaiting a vacation home for duties there.
I decided to drive it some the last few weeks and the first time I started it up, I got down the driveway and realized the climate control was dead - no lights on, can't adjust anything - completely out. I pushed all the buttons and nothing happened. So, I stopped the car, turned it off and restarted it. This worked - the climate control came on and worked normally for the rest of the drive.
Two days later, I started the car up and it worked fine.
The next day I went to go somewhere and it was dead again. I did the same thing where I stopped the car and restarted it - got nothing. I cycled thru the ignition again and it came on fine.
What is going on? Am I getting a short? I'm going to replace the fuse to see if that does anything, but has anyone heard of this issue before? TIA
Old Jan 26, 2009 | 08:42 AM
MINIdave's Avatar
MINIdave
My '03 has done exactly this - twice - since I've owned it, and turning the key off and on again always fixes it. Let me know what if anything you find out, OK?
I don't think it's a fuse, fuses don't fix themselves, unless it's corrosion on the contacts. I'm thinking a relay somewhere......
Old Jan 26, 2009 | 09:51 AM
ClubmanS's Avatar
ClubmanS
This is the reason why I ordered my 2005 with the manual climate controls. No worries over glitches in electronics as these components age.
Old Jan 26, 2009 | 10:39 AM
JAB 67's Avatar
JAB 67
This is a known problem. My 2004 has done it since new. There was a TSB on it - has to do with a ground wire, I believe - but it did not eliminate my occasional problem. Because it doesn't happen very often, and always returns to normal by timply turning off the ignition key, I have learned to live with it.
Old Jan 26, 2009 | 12:42 PM
MrCooperS's Avatar
MrCooperS
Moderator
Same here....It happened probably once every two months for me. It actually happened today for me and for some reason the radio was gone with it. I restarted the car and everything was fixed.
Old Jan 26, 2009 | 03:14 PM
karrera4's Avatar
karrera4
hmm...crazy! are there any threads that deal with locating the ground wire?
patsum
26
May 29, 2021 06:29 PM
IFIXEM2
Sep 18, 2015 08:47 AM
shahriar35
Sep 12, 2015 08:31 PM
Suspension Products
Sep 10, 2015 11:46 AM
Ntety
Sep 2, 2015 08:39 PM
