Wheel speed sensor faults
Old Jan 14, 2009 | 09:07 PM
second to none's Avatar
second to none
I have two trouble codes for both my rear wheels. I have no ABS or DSC lights (traction control light stuck on) problems. I was, however, vigorously testing the DSC on a strip of snow covered road at about 40 recently, and it works quite well. Could making it work back to back cause a code? There is no description associated with it like high resistance or no signal, etc. I did feel the rear wheels individually locking up, so I suspect it thinks its broken because its made to function on dry or wet roads and it thinks something is wrong with itself?
Old Jan 15, 2009 | 09:06 AM
Phantom's Avatar
Phantom
what code is it showing on the reader. And you say no DSC light, ABS or Tire press?
Old Jan 15, 2009 | 11:46 AM
frenchie's Avatar
frenchie
The right rear wheel speed sensor drives the speedometer; if the speedo is working fine then the RR wheel is good, must be a problem in the other wheel.
Hope this helps and good luck!
Old Jan 16, 2009 | 06:48 PM
Phantom's Avatar
Phantom
thats good to know for future use
Old Jan 17, 2009 | 09:28 AM
craigfsl's Avatar
craigfsl
have you got your car dyno'd lately it set those two off on my car
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:49 PM
Dashdog
Aug 10, 2015 06:17 AM
MES11
Aug 8, 2015 10:21 AM
