R52 08 MCS Cabrio
Old Jan 6, 2009 | 04:14 PM
bmackinlay4353's Avatar
bmackinlay4353
08 MCS Cabrio
I was changing out the black wheel lug nuts for some chrome ones and stripped one of the lug holes on the right front wheel!! What are my optiions?I have tried to rethread the hole thinking if I could just get it to start I could get it to catch,no such luck!! Help!!
Old Jan 6, 2009 | 04:50 PM
BlimeyCabrio's Avatar
BlimeyCabrio
New hub. About $200 for the part. Part #31226776671
My guess is that the lug bolts you tried are the wrong thread... MINI uses a strange thread...
Old Jan 7, 2009 | 03:16 AM
bmackinlay4353
No, I had no problem installing all 15 Nuts, but the very last one must have started off crooked and ruined the hole. If I had that hole bored out would the lug be larger then the other 15? . Where would I start to find someone to perform this task? Bill
Old Jan 7, 2009 | 07:46 AM
buzzsaw's Avatar
buzzsaw
Found this under Timesert/boltsizing that may be of help and a viable alternative.
Old Jan 7, 2009 | 12:35 PM
too cool blue!'s Avatar
too cool blue!
Don't worry about it...it happens all the time. Get a helicoil: http://www.helicoil.in/
Any garage or tire place should have them or be able to get them from any auto parts supply. If you don't want to install it yourself, just drive the car at a reasonable and safe speed, with the lug bolt missing, to the shop.
Old Jan 7, 2009 | 02:24 PM
HRCVF750's Avatar
HRCVF750
I wouldn't go with an insert or a temp repair... replace the hub... it's too critical a part to take a chance with.
Old Jan 7, 2009 | 07:22 PM
bmackinlay4353
Never, replaced a hub before, is it difficult to do? I have ordered one and it should be here by Friday, not sure if I should attempt to do the change over myself. Any tips would be appreciated. Bill
Old Jan 9, 2009 | 06:06 PM
bmackinlay4353
Hub Nut size
BlimeyCabrio Appreciate the part number for the hub,do you know what size the large nut on the hub ? Bill
Old Jan 10, 2009 | 05:59 AM
BlimeyCabrio
If you mean the hub bearing nut, Bentley Manual says it's 22mm.
wildwestrider
Dec 27, 2015 08:20 PM
ej
Nov 17, 2015 09:21 PM
