Rusty water pipes
Old Dec 30, 2008 | 06:08 PM
idickers's Avatar
idickers
Rusty water pipes
Anyone look at their water hardlines (arrow in pic) that feed the heat-exchanger under the oil filter ? You would not normally see these, but I was under my car and had removed the heat shields prior to removing the transmission. It looks like road salt from our NE winters has started to eat the pipes away. I'll probably remove these and give them a coat of POR15 before putting everything back together, as I hope not to see them again in the near future (too much work!).
Ian
'02 MCS, somewhat rusty after 5 NE winters
Old Dec 30, 2008 | 08:11 PM
Crashton's Avatar
Crashton
Cleaning them up & hitting them with some POR15 would be what I'd do too. I doubt that is more than surface rust.
Old Dec 30, 2008 | 08:28 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
That's the bad thing about them NE cars. All that salt from winter does a number on them.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 30, 2008 | 08:40 PM
Some Guy's Avatar
Some Guy
Uhg, really dont want to think about it...
Old Jan 1, 2009 | 01:46 PM
orvillespooner's Avatar
orvillespooner
There is also one that runs over top of tranny to water pump you had better check it as mine was almost gone thru. Easy to replace with tranny out, but you have to loosen the intake manifold.
Part no. 11537510760
http://www.realoem.com/bmw/showparts...00&hg=11&fg=35
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
Doc Pain
Oct 28, 2015 07:09 PM
vetsvette
Oct 11, 2015 06:05 PM
BossyR56
Sep 28, 2015 11:33 AM
