Suspension Can someone explain suspension components?
Old Dec 29, 2008 | 12:25 PM
k_h_d's Avatar
k_h_d
Can someone explain suspension components to me. Struts, shocks, springs, and their role... Springs just to support the weight of the car, shocks to dampen recoil? struts = shock?
Old Dec 29, 2008 | 12:29 PM
gnatster's Avatar
gnatster
This will give you a pretty in depth run through of the suspension along with how, why's and tradeoffs.
http://auto.howstuffworks.com/car-suspension.htm
Old Dec 29, 2008 | 12:50 PM
k_h_d's Avatar
k_h_d
That site was very informative. So after reading that right and so I have the right terminology. The mini has a strut which consists of the shock absorber and spring over the shock.
Thats basically a coilover system, right?
Old Dec 29, 2008 | 01:22 PM
M!N!-ME's Avatar
M!N!-ME
Nope, a coilover system has adjustable spring perches to lower or raise ride height as the end user sees fit. Some also have adjustable dampening settings integrated so the end user can adjust the ride to a preferred level of comfort(sport-race)
Old Dec 29, 2008 | 02:04 PM
#20Works4me's Avatar
#20Works4me
Struts in front, shocks in back, coil springs all round
Old Jan 15, 2009 | 02:44 PM
Silkworm's Avatar
Silkworm
springs support the wieght and how much wieght transfers based on stiffness.
Dampners adjust how fast that wieght transfers.
swaybars adjust body roll by linking left and right side of the suspensions together.
Way i see it anyhow.
Old Jun 26, 2009 | 09:33 AM
Storm180's Avatar
Storm180
Ok, maybe I'm just stuck on stupid, but I don't quite get it.
I've read the howstuffworks writeup (very informative), and from the pictures, it looks as if a Strut and a Coilover are the same thing, minus the adjustability of the coilover. Their pictures of a strut show a spring around the outside of the unit, like a coilover. Ok, fine. But when I go to try to purchase a Strut they look exactly the same as a shock. As one example, on MINI Madness' page (http://www.mini-madness.com/index.as...S&Category=209) the FSD struts and the Yellow shocks look identical for the front components. I understand there are differences between fronts and backs, so I'm just talking about front FSD's verses front Yellows.
I guess basically I have three questions:
1. Shouldn't a "strut" have a spring on the outside as part of the unit to be called a strut? Otherwise its just a shock, right?
2. Can I keep my lowering springs if I buy struts or do they come with their own that can't be replaced?
3. Or is all of this just one hell of a misnomer and there's really no difference until the actual part is combined with the existing spring like Voltron and put in the car?
Ugh...All this to figure out why I've got one hell of a right pull on my car and I'm blowing through my right tires. Thanks in advance for help clearing this up.
Old Jun 26, 2009 | 12:31 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Wow... you ARE pretty confused.
You'll find lots of conflicting definitions regarding the difference between a strut and a shock. One that I've heard is that a "strut" is a structural, load bearing component of the suspension - on the front of the MINI, if you remove the front strut, the steering knuckle flops over - the wheel won't stay upright without the strut. The strut actually carries a significant portion of the car's side load when cornering. A "shock" solely acts as a damper, not a structural component - which is true on the rear of the MINI. But, in another sense, some folks consider both to be "struts" because they work in conjunction with a coil spring mounted on the body of the strut itself (as you suggest). Clear as mud, eh? But it's a strut because is uses a spring around it to function - it doesn't only get to be called a strut after the spring is installed. The spring is not "part" of the strut. Short version - if you buy something call either struts or shocks or coilovers for a MINI - they are functionally the same things (except for the adjustability of the coilover).
Struts typically do NOT come with springs installed. Coilovers typically DO come with springs installed. But there are exceptions. But, for the examples you list, Koni FSDs and Yellows do NOT come with springs. You use the OEM springs, or add aftermarket springs.
See answer to #1. Shock/strut + spring (plus spring perches, plus maybe camber plates in front) = something that you install to actually do something. None of the components work individually without the others.
Old Jun 26, 2009 | 01:14 PM
Storm180's Avatar
Storm180
Ok. Now THAT makes more sense. Its the structural component that I was missing.
Thanks Blimey
Old Jul 5, 2009 | 04:34 PM
ninjlao's Avatar
ninjlao
Ninja Mini
Technically all McPherson type suspension setups can be considered as "coilovers".
What most people here refer to as coilovers are the suspension kits which have ride height adjustability as well as bound/rebound adjustments.
Filmy
15
Jun 6, 2023 06:27 AM
conky
Apr 6, 2016 08:03 PM
ej
Nov 17, 2015 09:21 PM
IrishMCS
Sep 15, 2015 05:43 AM
Sep 14, 2015 12:48 PM
