R56 How do you install head light bulbs?
Old Dec 23, 2008 | 02:23 PM
Bigjoeski08's Avatar
Bigjoeski08
I can't figure out to install these freaking head light bulbs
When I take out the factory headlight bulb this is what it is
And I try to push the little metal clip in and pull bulb out it doesn't come out
Can someone please help me with this i'm freaking out that I'm not able to install stupid head light bulbs.
Old Dec 23, 2008 | 02:32 PM
Squirlz's Avatar
Squirlz
Are you trying to take the assembly you have pictured apart? The Silverstar assembly replaces that whole thing. You just snap it back into the housing.
Old Dec 23, 2008 | 02:33 PM
krim's Avatar
krim
pretty sure you don't have the correct replacement bulb. Sylvania website says H13 or 9008, you have a H7.
Old Dec 23, 2008 | 02:34 PM
Bigjoeski08
So I don't have to put that black housing back in the car?
Old Dec 23, 2008 | 02:38 PM
Bigjoeski08
2007 mini cooper s (With replaceable halogen capsules)
Low beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
Old Dec 23, 2008 | 02:41 PM
Squirlz's Avatar
Squirlz
Well I'm going by my experience with an R53, where all you do is unplug the wire, pop out the old assembly like you show there, then put the Silverstars in and replace the plug. The H7 is correct for R53s. I know little about the new ones but I doubt it is changed.
Old Dec 23, 2008 | 02:42 PM
Bigjoeski08
I just checked Alta's website and they sell H13's for the R56 mini
Old Dec 23, 2008 | 02:43 PM
Bigjoeski08
So it's sylvania's website they are wrong it's H13's
krim's Avatar
krim
I did notice that the 2007 lists an H7 but..
2008 MINI Cooper S Coupe (With replaceable halogen capsules)
High & low beam headlamp
H13 (9008)
H13ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H13XV XtraVision Halogen - The Brighter Light
i'd go back to the store real quick and see if the H13 are the same as what you pulled out.
Old Dec 23, 2008 | 02:44 PM
Bigjoeski08
Ok thanks guys I was pulling my hair out i'm going back to the store now to replace these with some H13's thanks again.
Old Dec 23, 2008 | 03:14 PM
Capt_bj's Avatar
Capt_bj
Don't feel bad - their web site burned me on this very point...
I AM surprised that a year later it is still wrong .....
The owner's manual lists the correct bulb type.......
Old Dec 23, 2008 | 04:02 PM
Bigjoeski08
Wow just got back from pepboys and it's wrong in there system also listed as a H7 but there 2008 models are listed at H13.
Old Dec 23, 2008 | 04:37 PM
wandrur's Avatar
wandrur
Moderator
So...the replacement should be an H13 instead of H7?
Old Dec 23, 2008 | 04:40 PM
Bigjoeski08
YES the replacement bulb for 2007 and up non HID cars is H13
Old Dec 23, 2008 | 05:49 PM
wandrur's Avatar
wandrur
Moderator
Sonuvah...
Well, good to know now.
Thanks!
Old Jan 6, 2009 | 05:38 PM
wandrur's Avatar
wandrur
Moderator
H13s fit like a charm. Easy switch out. A noticeable difference at this point, but I haven't had the chance to drive around at night yet, so I'll report back at that point.
Anybody need a perfectly new pair of X-treme Power H7s??
phrza81
Oct 10, 2015 11:37 PM
cm.d
Aug 19, 2015 08:51 AM
jrezzo
Aug 9, 2015 10:32 PM
