Suspension Rear lower control arm
Old Dec 18, 2008 | 12:06 PM
Doc Cooper's Avatar
Doc Cooper
I need to get rear lower arm control for r56. My MCS is lowered on CROSS coilsover.... well i am seeing that im passed the acceptable camber for the rear so i need to correct it...
Looking for Hsport.. i only found one vendor selling for around $240.. any other place you guys recommend?
Old Dec 18, 2008 | 01:36 PM
gnatster's Avatar
gnatster
There is no difference between this part on the 1st and 2nd generation MINI's so any of the ones you see listed for R50/52/53 will work fine.
I am biased as live near and beta test for Texas Speedwerks. Worth looking I think.
Old Dec 18, 2008 | 02:59 PM
minipete07's Avatar
minipete07
http://www.jscspeed.com/mini_r56/sus...ntrol_arms.htm
Got these and i love them... great quality!
Old Dec 18, 2008 | 03:54 PM
Doc Cooper's Avatar
Doc Cooper
what you guys think?
Hsport rear lower control arm
http://www.tirerack.com/suspension/s...800&perfCode=A
Hsport sways
http://www.tirerack.com/suspension/S...egory=AntiRoll
THere are three kits available. 19mm, 25mm, and front and back one for $190.. i think the last one is best deal but do i need the fronts? I think rear is the most crucial no?
BTW... how long you think i start to notice irreversible uneven wear on my new tires?I just got some Eagle F1s. 201/50/16 from tirerack... i put about 500 miles... car has Cross c/o already... no alignment done
The car veers to the right now... haha yes i can go lower... all around... but i need to get rest of the suspension parts before i get an alignment... then ill be done with suspension...
Old Dec 18, 2008 | 06:12 PM
minipete07's Avatar
minipete07
all u need and be really happy with is the control arms and the 19mm REAR only,(absolutely no reason for front bar-and good luck installing it! if u do get it) the 19mm bar has three settings and is great for the street and the track
Old Dec 21, 2008 | 01:00 AM
ghosthound's Avatar
ghosthound
this may be a dumb question.... but do most alignment shops make use of the adjustable control arms?
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
