A good set of trackday wheels?
Old Dec 4, 2008 | 12:35 AM
futureal33's Avatar
futureal33
Hi all,
I am after buying a set of trackday wheels. The wheels will only be used for tracking so looks arent important!
I have black R105 alloys on at the moment and there is no way Im taking these anywhere near the track.
Im after something cheap and if possible lightweight...
Which of the OEM Mini Wheels are suitable?
Cheers
Old Dec 4, 2008 | 04:34 AM
snid's Avatar
snid
OEM MINI wheels for the track? Cheap and lightweight? ummm... none.
Look at Kosei, Team Dynamics and Rota for cheap, light track wheels.
Old Dec 4, 2008 | 06:16 AM
JSCspeed's Avatar
JSCspeed
The intersection of cheap, lightweight and durable is hard to find. We sell the Enkei Racing wheels, that are both durable and lightweight, and, well, cheap is relative I guess. Personally I'd opt for durable first, light second and cheap only if the first two requirements were also met.
The RPF1s are easily the most poplular/common Enkei Racing wheel at a track day (look at Miatas, Hondas and Minis).
We keep these in stock in most of the popular sizes...drop me a line if you need a quote.
Old Dec 4, 2008 | 03:46 PM
Alex@tirerack's Avatar
Alex@tirerack
Holies are great! I dont know if they will work on the new cars.
Were you thinking 15, 16 or 17?
Alex
Old Dec 4, 2008 | 04:25 PM
james f's Avatar
james f
Rota slipstreems, cheap and light and strong and a good offset cant beat that and unlike a lot of the others there cheep in the uk as well
Old Dec 4, 2008 | 04:39 PM
Oxybluecoop's Avatar
Oxybluecoop
Motegi Traklites
Old Dec 4, 2008 | 04:55 PM
darmog's Avatar
darmog
The lightest OEM wheel is the S-winders from what I've heard..
R102 S-winder ET48 17.4lb (7.9kg)
Old Dec 5, 2008 | 01:17 AM
jerjer's Avatar
jerjer
RPF1s are great option!
but anyone know if they are brake friendly?
Old Dec 5, 2008 | 07:02 AM
JSCspeed's Avatar
JSCspeed
15x7s 41et RPF1s will clear OEM R53 calipers. As for BBKs...that's a different, case by case story.
Old Dec 5, 2008 | 03:04 PM
jerjer's Avatar
jerjer
looking for 17x7 +35 hopefully will yield more space and less spacers needed for a pair of stoptech.. .
Old Dec 5, 2008 | 05:15 PM
PenelopeG3's Avatar
PenelopeG3
+1
Enkei Racing wheels are strong and durable and the price is reasonable.
Old Dec 5, 2008 | 05:42 PM
Robin Casady's Avatar
Robin Casady
I bought a set of CenterLine RPM 17x7 for about $170 ea. They weigh about 16 lbs. which is very light for a 17" wheel. The finish is polished aluminum, which means raw aluminum. So, they have to be waxed periodically to keep them from pitting. The finish quality is not great. The company has a very bad customer service record and earned a "F" rating from the BBB. Sometime ago this model wheel was known for developing cracks, but they seem to have redesigned them since then.
For 16" wheels, the Rota Slipstreams are only 13.9 lbs. and about $170 each. They have a better finish, and Rota seems to be a better company.
Old Dec 5, 2008 | 09:30 PM
CHKMINI's Avatar
CHKMINI
15" Mini Steel Hollies FTW. Lightweight, inexpensive and strong.
Old Dec 6, 2008 | 05:40 AM
Bullitt44's Avatar
Bullitt44
"Bullitt"
When making your decision check the manufacturing process. It also depends on how serious of a track star you are. Feel free to PM me with any questions. I do agree with durability and strength being the most important asset. Good luck and happy tracking!
Old Dec 6, 2008 | 06:08 PM
lttletimmy's Avatar
lttletimmy
Originally Posted by james f
Rota slipstreems, cheap and light and strong l
Not so sure about the strong part...
Before nordschleife lap:
After:
Other rota failures:
Old Dec 6, 2008 | 06:09 PM
lttletimmy's Avatar
lttletimmy
PS I run RPF1's and am very happy with them, and they're VERY well priced. You can find used ones for fairly cheap if you look around.
Old Dec 7, 2008 | 02:06 AM
YseanY's Avatar
YseanY
fikse makes some very strong and light wheels, but pricey!
Old Dec 7, 2008 | 07:00 AM
Axela's Avatar
Axela
I am also looking for track/autoX wheels in 16x6.5 sizes. I already bought 16" R-comps, so I plan to use 16"x6.5 width wheels (stock autoX class).
I've narrowed down to Rota Slipstreams since they are the most affordable. Pictures above makes me a little nervous... enough to consider more expensive forged sets, like Motegi Traklites and SSRs.
Old Dec 7, 2008 | 11:41 AM
Robin Casady
The question is, what did it take to do that damage? You can destroy any wheel with enough force...
Old Dec 7, 2008 | 12:04 PM
Axela's Avatar
Axela
Yes, any wheel can get damaged with enough force. I'm sure these incidences are blown way out of proportion.
Old Dec 8, 2008 | 07:44 AM
Alex@tirerack
This is not the 1st accounting I know of these type of failures. You don't see these dramatic issues in photographs from other brands.
Alex
Old Dec 8, 2008 | 08:23 AM
Axela's Avatar
Axela
Alex
Would you recommend Motegi Traklites? or any other brand on Tirerack (Enkei, Kosei) for that matter? Thanks.
Old Dec 8, 2008 | 10:11 AM
snid's Avatar
snid
light, cheap, strong... pick any 2
Old Dec 8, 2008 | 11:02 AM
james f's Avatar
james f
ouch, i feel quite glad you posted that was going to buy some as my track wheels teaches me to listen to my mates wheel advice
Old Dec 8, 2008 | 01:53 PM
JSCspeed's Avatar
JSCspeed
^Truth.
